E-Class (W213) 2016 - 2023
E63s Speed limiter removal
Old Feb 19, 2018 | 11:36 PM
LOGANXXX's Avatar
SL 63 AMG 2013 / C63S 2015/ BMW M6 2006/BMW Z4 3.5is 2010/ Porsche 996 C2 2000
Hello guys,
does anybody here got a speed limiter removal for The E63s w213?
Thanks!
Old Feb 21, 2018 | 07:27 PM
Wolfman's Avatar
Super Moderator
Originally Posted by LOGANXXX
Hello guys,
Thanks!
The speed is currently limited to 186mph. Not fast enough for you?
The only way to remove that limiter is to get a ECU tune that has no limiter. The car will easily go faster than 186 but you will only experience that in Germany
Old Feb 21, 2018 | 09:38 PM
LOGANXXX's Avatar
We are used To go faster than that in Brazil.
We even have 2 mile top speed competitions in closed AirPort space.
I’m already on Renntech tune but it does not remove the speed limiter.
Old Feb 21, 2018 | 09:39 PM
sam9187's Avatar
2014 S550 - SOLD, 2014 GL550 - SOLD, 2014 GL63 AMG, 2015 S63 AMG Sedan, 2015 S63 AMG Coupe
Even if there was no limiter where can you drive that fast? Track?
Old Feb 21, 2018 | 09:52 PM
LOGANXXX's Avatar
Track and some roads at late night.
I have some vídeos on my phone, but i can not upload mp4 files here.
Old Feb 21, 2018 | 10:24 PM
sam9187's Avatar
Look for a tune in that case. It will remove the limiter as well as more hp. I had eurocharged tune on mine and it was awesome. I had renntech first but which was expensive but I wasn't happy as it was lagging. The car wasn't responsive. I switched to eurocharged it was lots better then renntech and lot cheaper. I also have renntech in a GL63 which is awesome. I'm not sure what renntech changed or did differently in the s63.
Old Feb 22, 2018 | 03:47 PM
Wolfman's Avatar
Super Moderator
You have to check with each tuner if there is no limiter. That said, even without the limiter I assume are are good for maybe 10mph max. Normally the limiters aren't on the spot either and run a few mph over.
What has been your actual top speed? GPS or speedo? Speedo will be off a bit and show slightly higher speed.
Old Feb 22, 2018 | 06:23 PM
jhpmbusa's Avatar
2021 M550i
please do not do this on public roads, sounds outrageous and dangerous.... haha
Old Feb 24, 2018 | 10:37 PM
LOGANXXX's Avatar
311km/ph on The Hud.
then it hits The limiter.
my last SL63 hit 352km/ph without the speed limiter
Old Feb 25, 2018 | 10:22 PM
Wolfman's Avatar
Super Moderator
Interesting.
311km/h sounds about right. That will be about 305-6 in real speed.
I am not sure about the SL63 number. 320+ is no problem for a tuned SL but 352km/h is really not possible on a ECU tune alone. Any other upgrades? Be nice to see what the Vbox numbers are.
Either way, very strong numbers.
