Latest version of command?
#152
Had the software updated today at Mercedes. Latest version still seems 04.80.00.20. Noticed that although it enables the new style ambient light menu, I still don’t get the option to have animated light.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#153
Had the software updated today at Mercedes. Latest version still seems 04.80.00.20. Noticed that although it enables the new style ambient light menu, I still don’t get the option to have animated light. ![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
#154
What year is yours? Mine is a 2017 so maybe it’s too old for the animated light. Hoped it would be a software change but I guess there may have been a module change later on that enabled it.
I’m just over the moon to be able to use the touch pads in car play now!
#155
2019 E53 Coupe.
#156
That’d do it!
I had a 2019 demo that had it, but this one doesn’t. Noticed that the software change also didn’t add in the seat moving with the steering wheel when you turn on/off the engine, which I also thought was just going to be software.
#157
The COMAND update did fix my easy entrance/exit feature. The seat now moves. It didn’t originally.
#158
Ah ok, interesting. I read that in the US at least, the feature was removed in the W213 until 2019 due to some law suit issues with big people getting squashed!
I only looked at it briefly, but I only have the option to turn the Easy Access on or off, when you turn it on, the picture highlights the steering wheel but not the seat. The 2019 I had, had an option to choose wheel and/or seat and highlighted both in the pic.
I’ll have a play tomorrow.
Thanks!
Thanks!
#159
Thanks!
Thanks!
#160
Had mine done on 6/2 but have not noticed anything different. I need to check the version to see what it’s on. I totally forgot to check it before it went in for A2 scheduled service
#162
My Easy Exit/Entry started working with the update to COMAND version 04.80.00.20. Prior to that update, only the steering wheel and seat back (recline) moved.
#165
My car is going into Mercedes dealership at the end of this week. My easy entry seat movement isn't working, so its possible that my COMAND unit's firmware may be updated. I'll post on here if that is the case.
#166
I was at the dealer on 19th and they confirmed that 4.80.00.20 is the latest version. My easy entry seat movement isn't working either. There isn't even an option in the menu to choose Seat+Steering Wheel, like some others have in here. The image of the Easy Entry/Exit menu shows only the steering wheel highlighted. Dealer doesn't have a solution. Hopefully yours gets fixed.
SunnyC257 (08-25-2020)
#167
#168
Hi guys, does anyone know what the newest update is? Im getting my car back from the workshop tomorrow and I would like to know that I got the newest update(as the price is quite alot)
cheers, Jake
cheers, Jake
#169
Glowering (04-18-2021)
#175
You might be one of the first people to get that update. Do you have a pic of the dealer version menu so I could compare other software versions. Also what W213 do you have?
