Steering Wheel Up/Down Adjustment Not Working
Out of warranty and the dealer by me is horrible. Even MB USA acknowledges it, it is privately owned and they cannot do anything about it. This dealer is literally the worst thing about owning a MB. I seriously doubt I will buy another one bc of them. Great car otherwise. The same group also owns the BMW dealership, so I am not sure what I will do next.
Mine has been repaired 3 times, including replacement of the motor. It's making a "clunk" sound and is sticking again. Does anyone know if there is a service bulletin on this? Anyone else had repeated problems with this?
I just came from the dealer because I just got my rims done and as I got in my vehicle, I noticed that my steering wheel didn't move down. Read this article and the symptoms were the same so I pulled down on it real hard and its working just fine. the easy entry and exit is back to normal.
If your warranty has expired try the run in/run out and then pull down sharply (a firm jerk) on the top of the wheel. This worked twice for me. I had to do it twice because the Easy Exit feature runs the wheel all of the way to the top where the wheel becomes stuck. I have disabled the feature and now just raise the wheel manually with the handle when I want a little more room to exit. But not all of the way up.
What's the easy exit feature please?
This easy entry/exit feature is good to use, not only because of extra knee height allowance.... but it is to exercise your steering column UP/DOWN for those who is not using MAXIMUM up.
I too had my UP/DOWN steering mechanism not working once, it was kinda "stuck" for not being used for a long time. Press down long enough and it finally moved.
Play with UP/DOWN and telescopic up to max limit once a week is a good exercise to keep things lubricated and cleaning the steering column flexible cover from dust.
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
Had this problem with a recently traded ML350. Wheel stuck at the top.
This sounds assbackwards, but I found it I struck the bottom of the wheel upwards (with the palm of my hand) at the same time I pressed the down switch, the steering wheel would now engage. Try that several times and see what happens.
Also had the problem on a SL550 which got 'fixed' by the warranty. They told me to be sure I did not lean on the steering wheel when exitiing the vehicle. In other words they did not replace squat but got it working. Both cars gone now. New E450 Wagon will probably at some time do the same thing. It's in Mercedes DNA.
As mentioned before, this was a common problem with a few different Mercedes models that used similar electric motors. After a while of being in the same position, the electric motor "freezes". This is a common problem with these electric motors. I've had it happen 1 time on my E350, and took it in. My buddy at the mercedes dealer explained the issue, and mentioned that replacing the motor doesn't guarantee the issue is resolved because they are the same motor. The common way the Mercedes techs unfreeze the motor is by pressing up an down multiple times until it moves. I was under warranty, so they replaced it anyways. Problem went away, after a while, but came back. I have my easy access turned off. I remembered him saying the press up and down multiple times, and sure enough, it worked. Have never considered this to be a real issue since.
Coincidentally, I was at the dealership today and the techs said that it wasn’t covered by my CPO warranty. It pissed me off to no end.
So as a diligent consumer, I checked this forum and lo and behold and by moving it in and out and when full out I yanked the steering down sharply and it seemed to have fixed.
Don’t these idiots know that this is a lawsuit waiting to happen. Wait till someone gets killed because they weren’t able to adjust the steering and the airbag is not positioned properly. It will be a 100M + lawsuit!
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
I had the same problem today
https://www.idrivesafely.com/defensi...-airbag-safety
Your Position is Key for Airbag Safety: During airbag deployment, serious head injuries and trauma happen when people are not sitting in the correct position or fail to use their seat belt properly – if at all.
The National Highway Traffic Safety Administration takes this one step further, recommending you keep a 10-inch minimum space between the center of the steering wheel for drivers and the dashboard for the right front passenger. With that in mind, it’s best if the airbag deflates toward the broad expanse of your chest rather than the small area of your face. This protects the core of your body while still cushioning your head, minimizing your risk of serious injury.
I reiterate, this is a widespread problem and will bet that a lawsuit is just waiting to happen.
Not true. If the steering wheel is all the way up, you are going to make max impact with your head which will result in injuries. See below.
Probably nothing will happen. There are other issues like the leaking gas tanks where people would smell gas in the cabin and SBC brakes which could randomly fail and all that MB did was extend the warranty. Remember, the driver is the pilot in command. If the steering wheel won't go to the correct position or you can't adjust it properly, don't drive the car, it's not like the steering wheel is going to randomly pop out of position while driving.
Steering up and down not working on my Porsche was the steering control box
A few weeks ago my steering wheel stopped going up and down when trying to adjust it. I can still move it in and out, but it stopped going up and down. Has this happened to anyone else yet?
I plan on taking it to Mercedes when it comes time to do Service B in a few weeks, but I'm just curious if this happened to anyone, what they dealer said was the cause, and if they had a problem when bringing it to the dealer to get it fixed under warranty.
Thanks.
Thanks.
Hi I had a issue with my steering not going up and down so I checked the motor and was working just would go in one direction and so it would stop took a pliers and turned the spiral gear back manually and pushed switch and it would work well more trouble shooting I found was the control box that is for the steering it’s located on the top of the steering so you have to drop the steering column down to get to it and replace that part cost me 100 bucks and 2 and a half hours work valley imports of Fargo gave me a quote of 3000 to just replace the whole steering column well I’m not going to spend that on a older car so I figured it out on my own hopefully this helps the FYI guys.
What is "Commission driver's seat control unit." suppose to mean?
I was able to clear mine by extending the wheel out as far as it would go (more leverage that way) and it was the force at the bottom left part of the steering wheel that finally broke it loose (hits elsewhere did nothing).
Apparently, it's a bit temperamental. I was probably applying weight on the steering wheel while exiting the car at the same time the easy entry/exit function was active.
Memory controls moved the steering wheel as expected.
