E-Class (W213) 2016 - 2023
2018 E300 Center Display
Old Jan 4, 2019 | 05:35 AM
Vallie123's Avatar
2017 C43 Sedan and 2018 E300 Sedan. 2015 S550 gone.
So, when I choose ‘navigation’ for my center display area it ONLY gives me the 600 ft. View. Is this normal and correct and if not, how can I change it to one mile? Thank you in advance.
Old Jan 4, 2019 | 06:35 AM
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
You probably have auto zoom enabled. From the NAV screen, use comand, right push the center knob, scroll down to settings and click. Auto zoom should be somewhere in there. Disable it.
Old Jan 4, 2019 | 09:11 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
I use Navigation on the left third of the center screen, radio in the center. Wondered why the nav screen was 600 feet. Now I know!
However, when using navigation, the auto zoom feature is nice when you come to make turns. Hate to lose that feature.
I know I should use apple play and google maps instead of the built in navigation system!
Old Jan 4, 2019 | 09:43 AM
ua549's Avatar
If you press the nav button you can adjust the scale for a larger viewing area. When done press the radio button to return to the split screen. IIRC this can be done via voice command as well.
Old Jan 5, 2019 | 05:50 AM
Vallie123's Avatar
That’s interesting. Can’t wait to try it tomorrow. Thanks!
Old Jan 5, 2019 | 05:53 AM
Vallie123's Avatar
I tried that but it still returned to 600 ft. I have one other suggestion to try tomorrow and if that fails, I’ll swing by service. Thank you.
Old Jan 5, 2019 | 06:43 AM
haibieb's Avatar
2026 GLE 450 (Black on Brown Saddle)
Try to reset your COMAND screen.
Old Jan 5, 2019 | 07:33 AM
nycebo's Avatar
What about when you are driving in the highway, is it still 600 ft or does it adjust outwards a bit?
Old Jan 5, 2019 | 08:58 AM
JTK44's Avatar
Sometimes it is .25 miles but most of the time, at least for me, it is still 600 ft. even on the highway, regardless of what I set in the main navigation screen. Plus, I cannot figure out a way to change the size of it. It seems to have a mind of its own.
Can anyone help?
Old Jan 5, 2019 | 11:08 AM
Haag's Avatar
W213
Can anyone help?
Assuming you mean the part which I indicated with the red arrow in the picture it indeed has a mind of its own. You can not change the zoom factor yourself, it is autozoom depending on your speed.
Old Jan 5, 2019 | 11:24 AM
JTK44's Avatar
No I am talking about the main screen where you have the radio. (you picture shows the screen as 100% navigation) The screen to the left of the radio you have four settings:
1) Blank
2) Fuel consumption
3) Clock
4) Navigation
I also have the digital screen that you have pictured. I have mine set to "Classic". The picture you have posted I believe is the progressive.
Old Jan 6, 2019 | 07:07 AM
Vallie123's Avatar
So, I noticed today on the Freeway it will go to a quarter mile on its own but that’s it. Are you getting a wider view?
Old Jan 6, 2019 | 08:58 AM
nycebo's Avatar
I'm now noticing what you mean. I can adjust auto zoom on and off on main NAV display, but I'm unable to adjust it when on the media/radio screen, for example, and it occupies the left portion.
Old Jan 6, 2019 | 09:16 AM
JTK44's Avatar
NYCEBO:
This is exactly what happens to me: the screen next to radio screen stays at 600 feet regardless of what I do to the navigation screen - the large screen when in navigation mode - you call the media/radio screen.
I am going to Vermont today and will be both on the Interstate and rural roads. I will report back as to whether the screen changes from 600 feet.
Old Jan 7, 2019 | 12:10 AM
Vallie123's Avatar
That is it exactly. Kind of annoying.
Old Jan 7, 2019 | 12:11 AM
Vallie123's Avatar
NYCEBO:
I will look forward to reading about what you discover.
Old Jan 7, 2019 | 06:38 AM
JTK44's Avatar
Once on the interstate or rural roads the screen goes from 600ft to .25 miles -but no further.
Old Jan 7, 2019 | 08:48 AM
nycebo's Avatar
I noticed the exact same thing here in the NYC area.
Candidly, MB dropped the ball with the left 1/3 of the center display. I had high hopes for the dynamic option, thinking that it would show a lot more interesting info. Alas, it just shows an antenna for radio, the android logo for Android Auto, etc. Candidly, I would love it if the engine data summary could slot in there. Oh well. Maybe the NAV auto zoom improves with a software update.
Old Jan 8, 2019 | 06:51 AM
Vallie123's Avatar
Bummer but good to know it’s ‘normal.’
Old Jan 13, 2019 | 11:49 AM
JTK44's Avatar
This morning the screen was at .5 miles! However, withing 2 miles it went back to 600 feet. This was in local driving in my town - not on the interstate or rural roads.
I still cannot figure out what is happening!
Old Jan 13, 2019 | 05:03 PM
haibieb's Avatar
[QUOTE=JTK44;7653088]This morning the screen was at .5 miles! However, withing 2 miles it went back to 600 feet. This was in local driving in my town - not on the interstate or rural roads.
I still cannot figure out what is happening![/QUOTE
my take is that the COMAND system needs to be updated with the latest “update.” I had my issue with the Sirius and Radio discrepancies between the two screens that way corrected that way. The techs normally will check for TIPS and other recall bulletins only. Good luck.
Old Jan 13, 2019 | 05:06 PM
JTK44's Avatar
Doubt that is a solution: I picked up my car on December 27, 2018 - less than 3 weeks ago.
After the update on your car, were you able to adjust the nav screen - that is the 1/3 screen to the left of the main screen? (The screen that appears when you have the radio on - not the screen when you are in navigation mode)
If so, please post how you were able to do it.
