E-Class (W213) 2016 - 2023
Hermes Module
Old May 24, 2023 | 06:34 PM
W205C43PFL's Avatar
Originally Posted by yiannossavva
ehat you can do with that?
Mostly use to remotely unlock/lock, start engine, track location of your vehicle etc.
Old May 24, 2023 | 09:57 PM
yiannossavva's Avatar
Gcl 220d 2018
Any video for that? How to connect, how to use?
Old May 24, 2023 | 10:04 PM
W205C43PFL's Avatar
Is your car equipped with it? If your car isn't part of the chip shortage (and not waiting for the retrofit) it should had some sort of Hermes module.
Old May 24, 2023 | 10:16 PM
Gcl 220d 2018
Old May 24, 2023 | 10:26 PM
Gcl 220d 2018
Old May 25, 2023 | 09:37 AM
W205C43PFL's Avatar
I see then your car is equipped with it, sorry forgot to ask what country are you from? What features are available are region dependent I think.
Old May 25, 2023 | 09:39 AM
  #32
Gcl 220d 2018
I am from Cyprus
Old May 25, 2023 | 05:08 PM
  #33
W205C43PFL's Avatar
I am from Cyprus
Are you aware of other friends that have MB that have connective services provided by Mercedes? I wonder if it is enabled at all in your region.
Old May 25, 2023 | 10:32 PM
  #34
Gcl 220d 2018
no, but no one answer me, what exactly that module can do?
Old May 26, 2023 | 07:47 AM
  #35
ua549's Avatar
The Hermes module does outbound communications.
Old May 26, 2023 | 09:47 AM
  #36
W205C43PFL's Avatar
Sorry I forgot to answer you, here are the functions that it performs and won't be available without it:
https://cimg3.ibsrv.net/gimg/www.mbw...c3c1df165e.png
Old May 26, 2023 | 10:15 AM
  #37
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Further, it appears the car is an import from Japan? I wonder if that complicates matters.
Old May 26, 2023 | 10:20 AM
  #38
W205C43PFL's Avatar
Hmmm it does, if the connected features were available in Japan then it has a Japanese SIM, which means it won't connect in other countries as it won't roam.
Old May 27, 2023 | 02:45 AM
  #39
Gcl 220d 2018
Yes, import from Japan to Cyprus. I check if my chassis number is compatible with Mercedes me, unfortunately not supported. I can’t to anything with this module?
Old May 27, 2023 | 12:09 PM
  #40
W205C43PFL's Avatar
oh I thought you were OP, my bad. but no, unless you can somehow get the SIM in the module to work but I believe it is eSIM.
