Mechanical key replacement cost?
I'd pretty much given up on finding it, and began investigating how to replace it. My local MB dealer (not where I bought the car) said I'd need to replace the whole key and have it programmed; cost: $740.
I then talked to a locksmith who specializes in car keys. He didn't have the blank for my key, but said if I could bring him the right blank plus the mechanical key from my other fob, he could cut a replacement for $35.
When I started searching online, I found several MB mechanical key blanks, but nothing exactly like mine. My search was interrupted when the hotel phoned to say they'd found the missing key. They've sent it to me, and all's well again.
Now, mainly out of curiosity, I'm wondering if the dealer's whole-key line was bull****. Anyone here had a similar experience? Are there blanks to be found for 2019 mechanical keys? Is there some legitimate reason why MB would need to replace the whole key rather than simply cut a new mechanical key coded to match my VIN?
After losing the mechanical key, I pulled the mechanical key from my other fob and inserted it in the fob missing a mechanical. It fit and everything worked as it should. So I guess I'm not understanding why a locksmith or MB couldn't inexpensively cut a fully functioning mechanical key that would fit the fob and open the glove box (or car doors) manually. It just felt like the dealer (or MB) was trying to rip me off.
Apologies if I am misunderstanding what you are saying.
Still would love to know, though, if there's a legitimate reason --and not just price-gouging -- why MB wouldn't replace only the mechanical key, but insisted on replacing the fob, too.
The expensive thing is the controller, that will cost a lot more.
best regards.
I didn't take up the key-replacement question with the dealer I leased from because the key was found before I got that far. But for the sake of anyone else who loses a mechanical key, I'm hoping other MB dealers might be as reasonable as your BMW dealer.
From what you say, it sounds as if it was the dealer who lost your mechanical key, and was therefore obligated to replace it. They may have simply found it more expedient to give you a whole new key (fob plus mechanical) than to make you wait while they sent out a blank (if they even had any that weren't part of a whole key) along with your other mechanical key to a locksmith who would need both to cut a replacement. Or to order one from MB based on your VIN, as in the BMW example above.
Any idea how they made the mechanical key in your new fob fit your glove box lock?
I still haven't heard or read anything that explains why MB can't do what BMW did.
MB mechanical keys are produced by Huf. There is an Ilco blank, S34YS-P that may work with a bit of customization by a locksmith with the right tools. I'm not sure if the dimensions are right and the blank is missing a couple of notches. It won't fit in your fob.
I saw the public price in they computer before order (only the metal key blade)
https://www.youcanic.com/guide/order-new-bmw-key
"Typical cost for new BMW key is $300-$410 for the proximity key. This key has a metal blade inserted. The metal blade can be purchased separately for $45-$60 if necessary."
mboemparts.com sell OEM parts, and seems there is a part number for the mechanical key only for the C class, but for the w213 I don't see it
(don't lose your FOB-Transmitter, that thing is expensive!!)So I don't feel very confident that MB will be able to take orders only for the key in our e class based on that page, because there is no part number for it (I hope I'm relly wrong)
best regards.
key4.com is where I found blank mechanical keys.
Hey, I just want to jump in here and try to help. Sharing your key code is effectively giving the keys to your car to the world-wide internet. Even though it's very unlikely this would be used maliciously, it's probably not a good idea to have this information out here.
I suggest editing your post to remove the image with your key code in it, then go into your User Profile and locate your Album that holds all of your uploads and delete it from there also.
