TPMS on these wheels?
- I purchased a 2018 E400 and immediately changed the 19 inch wheels to 18's and replaced the RFT's with Michelin Pilot Sports A/S to improve the harshness of the ride.
- Some features on the 2018 were misrepresented to me and MB made it easy for me to change to my current car which is a 2019 E450
- I have never installed TPMS sensor in the wheels in the 2018 and would like to do it in the 2019 car. I understand that without the current sensors I have "passive" tire pressure monitoring (based on the rotation of the wheels) and that installing TPMS will give me "active" TPMS
- The wheels I have on the car (see attached photo) are OEM and I believe standard on E300's although Im not sure of this. I also believe that these E300's have active TPMS but again Im not absolutely sure.
- The local MB dealer service dept has not been very helpful. They say their system shows that these wheels are not compatible with TPMS but they can't be certain of that. The only way is to try it out and they quoted more than $1K Canadian for the experiment.
- I was able to purchase Mercedes OEM E300/400 TPMS sensors on eBay from a gentleman in Germany at a fraction of the Dealer quoted cost
Thanks in advance for any information or advice
All OE alloy wheels are compatible with OE TPMS sensors, and almost all non OE as well, the wheel on the picture above is 100% compatible.
TPMS works different depending on markets, in scandinavia TPMS is mandatory since 2014, the active TPMS in Mercedes sold on our markets cannot be turned off and will display an error message once sensors are missing.
I changed my rims and put aftermarket tpms
before it said no tpms installed
All it does it now it says active and I guess it’s reading but never gives any numbers now …tpms I bought said don’t need to be programmed they are auto programmed 433hz for w213
im not sure where is going wrong
EDIT: from the other thread I see you have been driving long enough. Either wrong type of sensors or they have not been correctly coded to match your car.
You could try to reset the tyre pressure monitoring system but I think a W213 should figure out new sensors automatically.
well I put them in a year ago and when i press start tpms it starts but never reads
I just put in a fresh set this morning drove about 5 mins back to my house in active mode nothing happens
I scroll down and it says “use new references as numbers or whatever” when I press it nothing happens
it’s like endlessly reading or something lol
