Atlanta dealer charges $170 to assess warranty repair?!
Is this normal?
Can anyone suggest more affordable options to assess the issue so that I can be confident the repair has a high chance of warranty coverage?
This is a 2017 E300 under warranty with 20k miles and a brake shudder that grows most intense from 40-30mph under braking.
See screenshot below.
My question is only about if other dealers charge this same fee if warranty repairs are not approved.
Thanks in advance for your help!
But, considering it's brakes, and brakes could just wear out (also, who did your tire rotations/installations?), I can see they have a leg to stand on. Many factors can lead to this, and they won't blindly replace the brakes and hope it works.
You are right about the troubleshooting, the attachment I provided states 4-5 steps to take to rule out other causes before approving a warranty repair.
If RBM also charges a fee, I will go to a more affordable independent shop first to do the first 4-5 steps, then take my receipt to the dealer to ensure I won't be charged a fee and the warranty repair will be approved.
Factory rotor warping on the w213 is a widespread issue with a service bulletin for warranty replacement, see the attachment from my original post.
Because there is such a small percentage chance that an owner's driving behavior would cause warping, because pads and rotors typically last tens of thousands of miles, because the car is in warranty, because the issue is widespread and a service bulletin exists, because this is not an unknown issue that would require hours of diagnosis and process of elimination (removing wheels and tires, checking balance, and visually inspecting rotors takes 20 min. max), a dealer is not justified in charging $170.
If they charged an hourly rate that is near the median of what other dealers in the area charge, and then a prorated amount of the hourly rate to perform the 4-5 quick inspection steps shown in the attachment, I would have no problem paying for 20-30 min. of actual work if the warranty repair is not approved.
It's the service advisor's implication that the warranty most likely will not cover the repair (against the known history contributing to the service bulletin itself), plus the upfront intention of price gouging, with which I find issue.
https://www.pelicanparts.com/catalog/SuperCat/9990/MBZ_9990_BRKDSC_pg1.htm#item1
$90 for brake pads
https://www.pelicanparts.com/catalog..._pg1.htm#item1
my dealer changed the discs 2 times in 2 years and under warranty!
not that it helps cos the problem always returns
See:
https://mbworld.org/forums/e-class-w...ke-judder.html
https://mbworld.org/forums/e-class-w...ver-100km.html
If no other dealer is more affordable than $170, I plan to take your advice.
Thanks again.
$90 for brake pads
It looks like Fremax supplies some OEMs and a lot of aftermarket applications. Other car forums' members seem to like the quality. I have the AMG Sport package so on CarID the appropriate Fremax drilled rotors are $86 each, a great price. If the warranty repair doesn't work out, I will try these out.
Thanks again.
See:
Thanks again.
Some dealers have no good will. They are not interested in the warranty “hassle”.
Others are more than happy to help.
I recently went to a dealer for a recall I did not know was already performed (when I had a chip in the paint fixed from a certified Mercedes painter ) and out of the kindness of my heart I decided to throw them some business because I have an aftermarket warranty.
The warrantee itself has language in it to make me responsible for the diagnosis if the repair is not covered.
I drive a ‘13 63 wagon.
I asked them them to look into a clunk up front. They could not find the clunk. They did not charge even with a thorough inspection and lead amg mechanic test drive. So after they were nice enough to not charge me, I asked them to check on an intermittent radar sensor issue. He alerted me that he would have to charge for diagnosis even if he didn’t find anything and it was not covered. I authorized this. After running a scan and deciding the problem was too intermittent to charge warranty for, he did not charge me. Ultimately, I went to a new dealer that did not sell me my car and they did not charge me at all. I am not under factory warranty either. It’s likely this dealer wanted to earn my business because they knew I had a long extended warranty.
I understand paying for convenience but I am also a real stickler for great customer service. It’s the only thing that allows me to go and give my money to a stranger and feel good about it regardless of outcome.
Good luck
Gary
Good luck
Gary
It's good to know there are still some great dealers out there!
On a good note, I did have a problem with my brakes (squeaking) on our current E class and MB did replace the rears (I think they replaced the pads) under warranty at about 2k miles. I had been complaining about the problem since I had 200 miles on the OD also.
I would find a good dealer and start a relationship with the service department. When I need them I always call and ask for the same advisor. I also pop in with doughnuts or some other things every now and then.
Good luck.
Pelicanparts sells the Fremax rotors and pads as well - they are great to deal with and if a first time order, you can qualify for a 10% off code too.
