E-Class (W213) 2016 - 2023
No warning message when hood open
Old Apr 6, 2020 | 08:49 PM
SunnyC257's Avatar
2021 CLS 400d
Hi,
when my hood is open, no warning message appears on the instrument cluster. Is this normal, or is this a malfunction?
If it’s a malfunction, is it an easy fix?
Old Apr 6, 2020 | 11:57 PM
madtrader's Avatar
2019 E450 Wagon
I know I’ve gotten the hood message before (first drive). I had to be moving above something like 25mph to get the message. In my case the hood was closed, but not completely. One of the, I don’t know what they’re called, was misaligned. But no message when starting the car, or just putting it into drive.
Old Apr 7, 2020 | 03:26 AM
joshg1001's Avatar
2017 E300
yah you have to be moving for it to give you a warning. It won't show on that graphic either
Old Apr 7, 2020 | 03:49 PM
SunnyC257's Avatar
2021 CLS 400d
OK I've released the hood latch and driven the car down the road, and the error message does come up- so it is all working!
Thanks guys
Old Apr 7, 2020 | 09:00 PM
2012 merc amg's Avatar
2018 S560
So I guess the E450's must have this message too?
Old Apr 8, 2020 | 12:40 AM
madtrader's Avatar
2019 E450 Wagon
Yes, mine is a E450.
Old Apr 8, 2020 | 07:50 AM
DFWdude's Avatar
2016 E350 Sport
Thanks guys
Last time my hood was ajar, I drove it a good 1/2 mile before the error message displayed.
Old Apr 8, 2020 | 01:06 PM
joshg1001's Avatar
2017 E300
So it depends on how open the hood is. For example, if you just pull the latch so the entire hood is unhooked, it will show the message pretty quickly. There have been instances where I closed the hood, and I usually just press down really hard on the center, where the entire hood looks closed. I didn't get the error messages for more than a few miles, possibly when I hit a bump in the road where the hood popped open a bit more. I learned that I shouldn't press to close the hood, but instead, drop close it so that it closes with a loud bang.
Old Apr 8, 2020 | 02:47 PM
DFWdude's Avatar
2016 E350 Sport
Yup, sounds horrible to let the hood fall, but that's how it works. My 19 year-old C-Class works the same way.
Old Apr 9, 2020 | 11:48 PM
rraisley's Avatar
2020 MB E450 Estate, 2019 Kia Niro Touring
Most/all cars work that way. A drop from a given distance is consistent. Pushing will vary with the person's strength, and with aluminum panels, BAD© things can happen.
Old Apr 10, 2020 | 07:57 PM
CaprichioArabe's Avatar
E450 Wagon, GLC300, E550
Headlights change when opening hood
I pulled into my garage the other day and decided to add washer fluid. The headlight pattern changed as soon as I pulled the latch under the dash. I turned the car off, but I assume it puts more light on the ground.
My last several cars all closed the hood by the drop method.
