E-Class (W213) 2016 - 2023
Seeking info on purchasing a spare tire
Old Jun 12, 2020 | 02:22 AM
lovemybenzo's Avatar
2017 E Class Black
I changed my tires to regular from the run flats, now I need to purchase a spare? Any suggestions, I need help?
Old Jun 12, 2020 | 08:38 AM
ua549's Avatar
There are several threads about spare tires. I purchased mine from a MB dealer. Whatever you purchase make sure the spare tire revs per mile matches that of the tires on your car.
In the case of an E300 with 245/45-18 the matching spare is a 135/70-19. The MB spare wheel does not require shorter lug bolts as most generic spare wheels do. Generic tools will work. I do not recommend purchasing the MB tools because they are several times as expensive as at Walmart.
Here are some specs:
Wheel Size 8Jx18 ET43
Tire size 245/45R18 26.7 revs/mile
Bolt pattern 5x112
Stud Dia & thread size m14 x 1.5
Center Bore 66.6 mm
MB Compact spare: 213-400-06-00 (135/70-19)
Old Jun 12, 2020 | 10:15 AM
Djackson13's Avatar
2015 s550
Hi, just checking to see if you received any responses on purchasing a spare tire. I am considering going away from the run-flats on my 2015 s class and will also be looking into purchasing a spare. Any feedback you can provide will be appreciaed
Old Jun 12, 2020 | 11:15 AM
ua549's Avatar
There are several spare tire discussion. Here is one.
Old Jun 12, 2020 | 01:16 PM
donaldm241's Avatar
2024 AMG EQE SUV / 2024 GLE 450e hybrid
spare tire kit
Look at Modern Spare Tire kit website. They have spare to fit plus the jack kit for approx $400 https://modernspare.com/contact-us/
Old Jun 12, 2020 | 05:46 PM
2017 E Class Black
Thanks for the info, so what is the jack in the trunk for?
Old Jun 14, 2020 | 07:12 AM
Camaroguy72's Avatar
2019 GLC300, 2017 E300
this. Or a roadhero kit is what I purchased before modernspare was an option (just under $400 shipped from the UK )
Old Jun 14, 2020 | 08:56 AM
dudley07726's Avatar
2023 BMW M340i, 2025 MB CLE53 AMG
We have 2018 E400 Coupe with 19 inch RFT’s that I wanted to replace with conventional ones. It was such a hassle. No dealer would confirm that the part number for the compact spare would fit my car. MB USA wouldn’t confirm it either.
in the end, I ended up purchasing a reconditioned wheel from Ebay to match the ones on the car. Ended up taking one of the RFT’s and put that on the wheel and will use that as a full sized spare if we take the car on a long trip.
turned out to be easier and cheaper than buying the compact spare.
https://www.ebay.com/itm/Factory-AMG...IAAOSwy11elgvh
Above link is what I purchased but not from the people that are selling it here.
Old Jun 14, 2020 | 10:53 PM
E300-18's Avatar
2018 E-300 4matic Sedan
If you have a jack, might as well test it out to see if it works for you. My car didn't come with one. I bought my spare tire from https://www.mercedespartshub.com/
The dealer was NO help for me. I found that quite frustrating.
Old Jun 15, 2020 | 07:31 AM
ua549's Avatar
Any generic scissor jack with a rectangular flat pad on top will work. The MB has an indented jacking point designed to fit the flat pad. I bought my jack at Walmart. It fits perfectly.
Old Jun 16, 2020 | 01:11 PM
2017 E Class Black
Ok thanks for the info, I did look at modernspare.com. So I'll be purchasing that spare.
Old Jun 16, 2020 | 04:18 PM
jhpmbusa's Avatar
2021 M550i
what did you replace it with and how much better is it compared to the run flats??
Old Jun 16, 2020 | 04:46 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
FYI:
I have a 2019 E450. Tires are 245/45X18 run flats. In the event of a flat, I carry a high quality air inflator, in my trunk. Hopefully I will be able to use the inflator to keep the pressure up in my run flats, so as not to ride on the sidewalls and destroy the tires, as I try to limp to a gas station to have the flat fixed.
I have decided not to use the sealant as it will ruin the TPS system and coat the wheels. After two hours, the sealant hardens and I have read that is cheaper to replace the wheel than pay to have the sealant removed.
As to a spare:
Just went to: https://modernspare.com/product/2017...-modern-spare/
and had a chat session:
The sku for the spare is SKU: MERE1726W
The price is $279.95 plus $40 shipping - no tax.
I already have a scissor jack, and other equipment to remove and change a tire.
My problem is that the spare does not fit in the well in the trunk and I really do not want to give up the space in the trunk for the spare.
Hope this helps.
Old Jun 22, 2020 | 11:44 PM
2017 E Class Black
I replaced with them with Goodyear Eagle Sport , I like the ride.
