E-Class (W213) 2016 - 2023
Oil specs
Old Jun 20, 2020 | 04:38 PM
mikefamig's Avatar
2005 R230 SL-500 / 2017 E300
Oil specs
I'm about to change the oil on my 2017 E-300 and have a quick question. I've been using Mobil-1 0w-40 European oil in my 2005 R230 Sl-500 and I'm considering using the same in the E-300. I've seen the Mobil-1 Formula M 5w-40 oil recommended for the E-300 among other Mercedes.
My question - what is the difference between M1 Formula M and M1 European other than the viscosity if any and is there a significant difference between the 0w40 and the 5w-40 oils? Can anyone give me a reason to choose one over the other?
TIA, Mike.
Old Jun 20, 2020 | 04:57 PM
mikefamig's Avatar
In addition to Formula M and European Formula I've found Formula FS 0w40 Mobil 1 which looks to be the same as the European Formula.
I'm sure that they will all do the job but does anyone have any preference?
Mike.
Old Jun 20, 2020 | 05:29 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Just my $.02:
I agree they are all about the same and if there is a difference it will be so minor as not to bother: remember you are changing it every year or 7,500 miles with filter, whichever comes first.
My choice would be: whichever is cheaper!
Old Jun 20, 2020 | 06:37 PM
mikefamig's Avatar
Originally Posted by JTK44
Just my $.02:
The same for both cars? The R230 is normally aspirated 8 cylinder and the E-300 a 4cyl turbo. The E-3000 specifies MB 229.5 type oil requirement which makes things simple but I can't find the same spec for the SL. Do you know if the SL also calls for 229.5 type oil?
Mike.
Old Jun 20, 2020 | 09:06 PM
cetialpha5's Avatar
Basically any oil that meets the MB 229.5 spec is fine. Mobil 1 0w40 usually gets pretty good reviews and can be easily had at Walmart for $22.88 for the 5 quart jug and Mobil 1 has a $10 rebate on a 5 quart jug til September 30th so it's the best bang for the buck.
https://www.walmart.com/ip/Mobil-1-E...Quart/23636902
https://www.mobil.com/en/lubricants/...e-program-2020
Old Jun 20, 2020 | 09:17 PM
JTK44's Avatar
Costco has 10 quarts for $29.99
see: https://www.costco.com/kirkland-sign...100527865.html
Old Jun 20, 2020 | 09:21 PM
cetialpha5's Avatar
They don't have a European formula that meets 229.5. Check the list I mentioned above. Kirkland isn't on it.
Also with the rebate, it's $12.88 for a 5 quart jug of Mobil 1, vs $15 for Costco oil.
Old Jun 20, 2020 | 10:21 PM
chassis's Avatar
2017 GLE350 4MATIC
@mikefamig given that you own an SL and are DIYing the oil change, you are likely familiar with the BEVO Mercedes operating fluids website. Look up your vehicle and all the acceptable oils will be listed for you. I would go with the cheapest and most available in your area.
In short it doesn’t matter. As long as it meets the MB spec and is changed in the MB interval.
Old Jun 21, 2020 | 01:04 PM
mikefamig's Avatar
Yes I've seen the Mercedes oil spec list that you linked to and I agree with you but I was wondering if anyone knew the difference between "Forula M" " Formual FS" and :European formula".. I kow that I can look for MSDS sheets on each but it's not worth the trouble to me.
I'm going to just use the European 0w40 in both.
Mike.
