E-Class (W213) 2016 - 2023
w213 noise problems
Old Feb 23, 2021 | 11:26 AM
Mihai Miron's Avatar
E220 2017
w213 noise problems
Hi. New here I do have a problem with my e220 2017. Basically when I am driving I can hear all the outside noises. I can hear wind blowing around windows, wheel noise that is really bad, other traffic participants noise, and from the back of the car is coming even a more loud one, almost like I am driving without a trunk. Anyone who has or had this problem? And is there a solution for that? I have been to the dealer that i purchase it but they say that is wheel noise. I know that they are wide but can't be that bad.
Old Feb 23, 2021 | 03:08 PM
JakeW213's Avatar
W213 220d from 2016
I have a hard time understanding what you mean? Is this noises that you don’t hear in other cars?
I would try different things to rule things out... try to borrow another similar car to your own and see of it has the same noises.
my 220d with 342,000 km on it has no noises and I run 255/35-20 on all wheels with wintertyres at the moment
Old Feb 23, 2021 | 03:27 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
in general it's the door rubbers,
I have yet to get a new MB where the dealer did not have to adjust them...
Old Feb 23, 2021 | 03:35 PM
ua549's Avatar
What is the brand and model of the tires? Winter tires are usually excessively noisy as well certain tread designs. tirerack.com has some very good technical info about tire noise. If you are in the EU, check the noise rating - 1, 2 or 3 waves - with 1 being 3dB or more below EU requirements. Studded winter tires are not rated.
Old Feb 23, 2021 | 03:50 PM
E220 2017
I do have 225/55 r17 but I do not know if it is because of that. I will try apply door rubber. I do not know exactly how to explain but you basically just hear everything that is outside when driving on motorway. Wheel sound, wind sound. I know is normal to hear but I think it is a bit excessive for a premium car. EDIT: Oh and all are winter tyres.
Old Feb 23, 2021 | 04:15 PM
ua549's Avatar
There is no way to make winter tires quiet. They are designed for winter traction, not for being quiet.
Old Feb 23, 2021 | 04:19 PM
E220 2017
So you recon it s the tyres. I will try and change them and also add some door rubber. Will update the post after with the results. Thank everyone!
Old Feb 23, 2021 | 04:46 PM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
I put winter tires on my wagon every year and when they are taken off in the spring the quietness of the non winter tires is very noticeable. Winter tires are noisy and squishy.
They are coming off next month and I cannot wait! It’s like putting on new sneakers!
Old Feb 23, 2021 | 05:21 PM
ua549's Avatar
TireRack has noi se rating for the various tires they sell. It is worth while to review specs for any tires you are considering purchasing. There are significant noise differences between models of the same brand as well as between different brands.
Old Feb 24, 2021 | 03:31 AM
Egonvdv's Avatar
don't ADD door rubber, the dealer can ADJUST/REDO them.
only a small leak can cause a lot of wind noise
Old Feb 24, 2021 | 10:46 AM
mercedes.fan's Avatar
2019 E200 sedan
Well the car isnt whisper silent, you will hear road noise and wind noise. The road noise will be very noticable on rough tarmac (like where I live). Not much you can do about it, new tires with lower noise marking can help and check that all the door seals are intact. If you can drive a similar e class and compare, if the noise is about the same your car is fine.
Old Feb 24, 2021 | 10:48 AM
Egonvdv's Avatar
and let's not forget; the engine is so quiet that it won't mask sounds from outside....
Old Feb 24, 2021 | 11:50 AM
The_Judge's Avatar
2018 E400 Coupe
As for your tires, are they run flats? Is so, know that in addition to being horrible in every other way, such tires are considerably nosier than are regular tires.
Old Feb 24, 2021 | 12:37 PM
E55Greasemonkey's Avatar
This place is a joke.
The 213 is not a premium car. It's a long wheelbase 205 (c-class) with a different interior and bulged body panels. First Mercedes for you? Your expectations may not be realistic.
Old Feb 24, 2021 | 12:45 PM
The_Judge's Avatar
2018 E400 Coupe
Define "premium car."
Old Feb 24, 2021 | 01:12 PM
JakeW213's Avatar
W213 220d from 2016
I would say that a w213 is more premium than any american, korean, french car I can think of(if we don’t consider bugatti real french)
But if a premium car in your world consists of rolls royce(bmw) bentley(VAG) Maserati(fiat)
And premium basically comes down to what you pay for it... then a w213 is not up there.
but to me its the best car I have had and even driven
Old Feb 24, 2021 | 01:17 PM
ua549's Avatar
I have an '18 E300 with a very noisy M274 engine. It sounds like a diesel because of the direct fuel injection.
Old Feb 25, 2021 | 12:59 AM
Jetaged's Avatar
2021 E450 Coupe, AMG Pkg. Obsidian Black with Mocha Interior
I just turned in my 2018 E400 and took delivery of my 2021 E450, there’s noticeable difference in wind noise on the drivers side window area. I heard nothing in my E400, now I’m hearing wind and road noise. This can be adjusted???
Old Feb 25, 2021 | 03:00 AM
Egonvdv's Avatar
i repeat: start with the door seals. all my new Mb's had this problem, but can be easily fixed
Old Feb 25, 2021 | 09:01 AM
konigstiger's Avatar
'71 Pinto
Dealer should inspect seals but yes they can adjust inner dust shield that may be too far forward.
Old Dec 10, 2022 | 02:14 AM
Stašjė's Avatar
E300 w213
sorry,you talking about seals on the cars frame? My cars has too much outside noises in the cabin,too
Old Dec 20, 2022 | 03:01 PM
parkwood's Avatar
EQE 500 4MATIC replacing EQC 4matic AMG line P
no the c class has its own estate variant an s205 model . I moved from a c to an e class estate they are quite different
Old Dec 21, 2022 | 11:53 AM
Bfgslkman's Avatar
From: Northern Germany and sometimes Southern Germany
Mercedes E220d AMG Line Estate (S213) and Mercedes E220d AMG Line Cabriolet (A238)
don’t be so rude - the diesel is silent on the move when cruising!
Old Dec 21, 2022 | 11:55 AM
Bfgslkman's Avatar
to be fair they do have the same floorplan and the towbar for the c/e are interchangeable between their respective bodyshells. The only difference is that the rear overhang is a bit longer on the e. Front/core/roof architecture is the same….
