E-Class (W213) 2016 - 2023
2018 E-Class Interior Wood Damage
Old Aug 5, 2021 | 03:53 PM
steveincowtown's Avatar
2018 E- Class
I am supposed to be picking up a 2018 Polar White E Class tomorrow, but one of the pics from the inspector has got me questioning my decision. Check out all the wood chips around the vents in the dash? Any experts car to take a guess as to what caused it, if it is covered under warranty, and if not how much it would be to replace? Thanks in advance for your help.
Old Aug 5, 2021 | 07:17 PM
6speeddave's Avatar
MB
This is interesting to see. Humidity from the air vents. Its important to wipe down any AC moisture if it builds on long drives so it doesn't soak into the wood and cause this.
Old Aug 6, 2021 | 02:12 PM
AzurSL's Avatar
1986 Light Ivory R107 560SL & 2024 W206 Starling Blue C300 4MATIC AMG-Line, Exclusive Trim
My guess would be that the car was parked outside instead of garaged, and the sun and the heat got to it and caused it to split. I've seen it happen on the W205 forum every now and then with the open pore woods.
Old Aug 7, 2021 | 12:13 AM
SteadyRover's Avatar
2017 GLC300, 2020 E450 Wagon
I’ve seen the same issue in a few used W213s on a MB dealer lot in Sarasota, FL. That put a swift end to my dithereing on getting open pore for my S213 custom order.
Old Aug 7, 2021 | 12:14 PM
TugboatBill's Avatar
2018 E63S Wagon, 2017 Z51 Corvette
One thing to be aware of is the wood pattern from MB carries onto the doors. If you replace just the center you'll lose that.
Old Aug 7, 2021 | 12:25 PM
chassis's Avatar
2017 GLE350 4MATIC
Don’t take delivery of or pay for that car until the dealer replaces the wood trim panel.
Old Aug 7, 2021 | 12:55 PM
r3dbenz89's Avatar
W213 E53 | 992 C2 | G20 330i
Further proves MB uses real wood veneers and not plastic as some ppl have tried to claim
Old Aug 7, 2021 | 01:10 PM
LaciCLK320's Avatar
C300, CLK320(sold)
Further proves that MB using low quality materials! 🙁
Old Aug 7, 2021 | 01:29 PM
W205C43PFL's Avatar
You can option the high gloss wood in which they seal it. Although I too prefer the open-pore wood as it is. On a side note, I never heard of wood chipping on a MB ever, so I am surprised this is a thing. In Canada, we have brutal winters and can be considered brutal summers (although short) so it should be the perfect condition for these issues to arise.
Old Aug 8, 2021 | 08:19 PM
chassis's Avatar
2017 GLE350 4MATIC
I replaced the front passenger door wood trim on my GLE this spring, and snapped the old panel in half, intentionally, to see how it was made. Yes, wood. A very thin layer of wood, sandwiched between plastic or topcoat, and a thin metal backing plate. This sandwich was adhered to a plastic carrier into which the switches, buttons, wires and fasteners were attached.
Old Aug 9, 2021 | 05:02 PM
W205C43PFL's Avatar
Thanks for sharing your findings, it is always interesting to see things from the inside.
Old Aug 9, 2021 | 08:50 PM
2018 E- Class
Thanks for the replies gents. I am going to take it to the dealer and see what they say. IMHO if wasn't damaged by the previous owner, it is a warranty issue.
Old Sep 5, 2021 | 12:32 PM
Pioneer222's Avatar
W213 AMG 2019 E63S Wagon
Following... Does anyone know if there are wood products or oils that might increase longevity? FYI, I often wipe the black ash down with the same cloth I used to treat the leather. I am guessing a little Lexol can't hurt the wood...
Old Sep 5, 2021 | 05:20 PM
AMG RB's Avatar
The horses are now in the barn, 2019 E63s
6speed, if you've got the whole shebang I might be interested.
Old Sep 5, 2021 | 06:12 PM
6speeddave's Avatar
MB
Sold.
Old Sep 5, 2021 | 06:26 PM
AMG RB's Avatar
Thanks for the heads up.
Old Dec 11, 2021 | 02:05 PM
2018 E- Class
Howdy, the dealer ended up replacing the wood dash under warranty. I still have this piece if you are interested.
Old Dec 11, 2021 | 10:38 PM
Cao Black's Avatar
2015 ML350+2025 E350
Glad they took care of it. Could you post a couple follow up pics?
Old Dec 14, 2021 | 10:20 AM
2018 E- Class
For sure! I pushed for them to replace the door panels as well but to so avail. I am satisfied with the results.
Old Dec 14, 2021 | 01:07 PM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
Another data point here. Have grey ash wood on my 2021 E450 wagon that was starting to split on drivers door, center console, and right dash piece. Dealer replaced under warranty (actually took it to another dealer first who said it was caused by chemicals although that's not true since I use a dry microfiber), but did not replace pieces that weren't affected. Overall, still matches pretty well.
Old Dec 14, 2021 | 04:04 PM
2018 E- Class
To be honest I have been pretty surprised what my local dealer has covered under warranty. Basically when I took it in the service advisor said that the car needed XYZ, I told him no problem if he could get a couple of issues covered under warranty I would bring the car back and get services XYZ. Suddenly all the BS I wanted to be covered under warranty had no issues. I won't enumerate them on here, but the $200 service he charged me for netted about $2K in warranty replacements.
