E-Class (W213) 2016 - 2023
Door handle lights
Old Oct 9, 2021 | 09:02 PM
Billyismyname's Avatar
W221/W222/W213/X290
Door handle lights
anyone have this issue where their door handle light isn’t turning on? Unsure of the bulb burned out or?
Old Oct 9, 2021 | 09:51 PM
W205C43PFL's Avatar
These lights are low quality LEDs unfortunately and do burn out, replacing them requires a dismantle of the door, basically. Mercedes simply stop putting LEDs there starting model year 2021.
Old Oct 10, 2021 | 01:37 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
I hate those LEDs and would love to know how to simply disconnect them. All they do is show off the dust that gathers behind the handle. Makes a great exterior look... anything but great.
Old Oct 10, 2021 | 04:05 PM
konigstiger's Avatar
'71 Pinto
Front & rear right light 0998200283 or MB direct 099820028364 (same part), left 0998200183 or 099820018364. Mounted in bearing bracket under door handle accessed from inside door. Have dealer replace under factory warranty.
Old Oct 10, 2021 | 07:34 PM
W205C43PFL's Avatar
I wish we can swap lol as I really like seeing the lights at night but all mine on a 2017 C-sedan burned out, but to answer your question, likely there is a fuse you can pull or you can use some dark coloured tape and cover the LEDs. The more annoying solution would be to take apart the door and unplug the lights physically.
Old Oct 10, 2021 | 08:12 PM
W221/W222/W213/X290
you are the man. Thank you good sir!
Old Oct 11, 2021 | 01:08 PM
murman's Avatar
I'll probably go the dark tape route and hope for the best. Gawd only knows what would happen if I started pulling fuses! I'll bet there's no dedicated fuse for that teeny bulb.
Overall, first world problems, amirite?
Old Oct 11, 2021 | 02:04 PM
The_Judge's Avatar
2018 E400 Coupe
Door handle lights? Sounds like one of the most useless accessories yet devised by man.
Old Oct 11, 2021 | 04:19 PM
W205C43PFL's Avatar
Yup.
Old Oct 11, 2021 | 04:59 PM
2012 merc amg's Avatar
2018 S560
Mine still all work on my S class and my E class but when they burn out I'll just leave them alone unless the cars are still under warrantee, although I dunno maybe the extended warrantee wont even cover these as they are something that wears out.
Old Oct 11, 2021 | 06:39 PM
W205C43PFL's Avatar
I am at least hoping the S-Class gets better quality LEDs? I was hoping the same for the E-Class too (compared to C-Class) but apparently it didn't happen after seeing them burn on the W213 too.
Old Oct 11, 2021 | 08:40 PM
2018 S560
Ya, I'd be willing to bet they are all the same cheap LED's. You think about it too and they do take a lot of vibration from people constantly grabbing the door handles. I'd be willing to bet the drivers door one is probably always the first to go since that gets the most use.
Old Oct 11, 2021 | 10:07 PM
W205C43PFL's Avatar
Probably actually, that reminds me of a few years back when I saw posts of a complaint for the ambient light strip dying randomly on the driver's side.
