Active brake assist
How else would you safely test it without crashing the car if the system did not work?
I'm pretty sure that how NCAP around the world do their test.
DISTRONIC slowing down if traffic ahead slows down is not the Active Brake Assist. That's just DISTRONIC doing its thing, and if you step on the brakes while DISTRONIC is engaged, it will automatically disengage, so obviously no longer slowing down for you. Also, DISTRONIC has a maximum deceleration rate of about 50% of the possible brake force. If it detects that it can't slow down enough on its own, then you get an acoustic alert to help it by stepping on the brake pedal. I'm assuming Active Brake Assist would kick in as well in that situation if you don't help it along, but I never dared to try.
1) I was on a 2 lane road and the car in front of me was turning right onto a side street. I knew I would clear their bumper, wasn't even close, but the car applied the brakes, and made a sound.
2) In a sharp left hand curve, an oncoming car that was going above the speed limit, came into my lane, and my car applied the brakes, as I was veering off to the right.
I am pretty sure someone or all these issues have been resolved in newer models. I have spent enough money on this one with on 30,000 miles on it, so for the 1st time in over 30 years I will be keeping a car longer than 3 years regardless of weather I have leased or purchased
I still love the car even more than when I 1st purchased it. This is also a 1st and one of my reasons for keeping it not to mention all the software updates and features I have had installed
Despite the startling nature of it, I keep it on – rather be safe (not scrape up this beautiful car) than sorry.
I had full understanding of the environment as well as the control of the car in both incidents. So, activation of the ABA totally surprised me as I did not expect any need to intervene. I thought I had really hit something for the first time as there was a very loud noise. I stopped the car and quickly checked around and saw no damage and realized later that it was the ABA being in use.
What worries me is that I was, perhaps, lucky as there was no car behind me as these 2 sudden full stops might cause me being rear-ended. For this reason, I am still debating whether I should keep this ABA feature enabled or disabled.
Regardless, I wish Mercedes would make an improvement:- Whenever this feature is used, a flashing message (eg. ABA has just been used) should come up briefly in the front Driver Display (or the Central Display) to inform the driver.
Edit:
Mine should come up with the following:-
I did a quick test today. When approaching a slower moving car in the front of me to a certain close distance, the triangle warning red sign did show up (red-circled in the pic) with an audible beeping warning. This is good!
I suppose the entire red rectangle should come up if ABA is triggered to stop the car completely.
But I do not think one ever showed up. Granted that it might have come up for a brief few seconds and I could have missed that (as I was paying full attention to the surrounding rather than to the Driver Display). That is why I hope there is a Message folder where it stores all the messages so that the driver can go back into to check what has happened earlier.
Last edited by bishop64; Dec 10, 2021 at 04:42 AM. Reason: Adding content under Edit
I am happy with it since it is statistics after all:
- If it brakes and avoids an accident - fantastic
- If it brakes without any reason without any accident - absolutely acceptable in the rate I have seen. Normally you get an warning before, only situations for me driving the car since 2016 is when going backwards without a foot on brake pedal (didn’t have time to move it to brake pedal). All other incidents have been with audiable warnings before correctly more brake power
- If it brakes without any reason creating an accident with e rear ending - you have to have a car close to your end which is not the case all times.
Edit:
One more comment, though, regarding false positives that just occurred to me. ABA and all the safety systems get more advanced if the car is optioned with the Driver Assistance Package. There's a basic level that comes with the car, but with DAP they become more sophisticated, and likely more reliable and accurate. One reason for that is with DAP, the car has a stereo camera up in the windshield, whereas w/o it there's only a single camera and DAP also adds the forward facing radar sensor for DISTRONIC, which also acts as an additional input for ABA etc. Therefore with DAP, ABA can for example distinguish between moving and stationary pedestrians and cyclists to make false positives less likely. I have DAP in my car, so for example I get a warning if it detects a pedestrian waiting to cross the road, but it doesn't slam on the brakes if there are pedestrians or cyclists nearby, unless they enter my path. W/o DAP, ABA is limited to only a single camera to detect objects, and therefore has no depth perception, so it can't tell how far away an object is or whether its really in your path or off to the side just enough.
I now reckon, instead of reading a few sections, I need to read the entire 600-page User Manual, systematically page by page from cover to cover. Per your mentioning, there are really a lot of technology integration among various packages. Eg I have Active Ambient Light Package which, when enabled, give additional warnings (audio and visual) in the Central Display.
Looks like it will be a lot of reading during the Christmas and New Year holidays.
https://www.mercedes-benz-mena.com/e...ncepackageplus
The VIN Decoder Report for this vehicle lists related options as follows:
* Code 237 - Active Blind Spot Assist
* Code 258 - Collision Warning System with Active Brake Application FCW-Stop
* Code 299 - Pre-Safe
Additionally I can confirm the car has a single camera behind the windscreen by the rear view mirror. It does not have radar and it does not have Distronic Cruise Control. It also doesn't have Active Lane Keeping Assist or Steering Assist. It does have 360 degree surround cameras for parking, but that probably doesn't play any role with FCW.
I'd very much like to know whether or not the car has the Autonomous Braking Function. Some reports suggest it wouldn't have Autonomous Braking if the car isn't equipped with Distronic. Other reports say differently. The car has never been close enough to a collision situation that required Autonomous Braking and I don't want to test it to the limit. The car once very briefly assisted by boosting brake pressure when I was already applying brakes, leading me to think the FCW system is functioning as intended for this vehicle.
Any input will be very much appreciated! Thank you.
