E-Class (W213) 2016 - 2023
W213 - HELP!!! Adblue - Cannot Measure Fluid Level
Old Jan 2, 2022 | 11:24 AM
Shaney75's Avatar
E200 CDi
Hi All,
My E220 2017 now has engine management light on but fortunately I can see the reason why. The adblue level is not measurable on the indicator on the digital display. I know the adblue tank is 75% full. It started flashing the level indicator on and off with 6,500 miles on it but now is just permanently off with the message “Cannot Measure Fluid Level”. Fortunately it hasn’t put me on a countdown timer to when the engine will shut off. Any ideas would be greatly appreciated.
Old Jan 3, 2022 | 02:27 AM
Diesel Benz's Avatar
The level sensor gone at the AdBlue tank, seems to be a common issue.
Old Jan 3, 2022 | 04:40 AM
Shaney75's Avatar
E200 CDi
Thank you for replying. Is this an expensive job to fix and am I ok to run the car? Everything seems fine when driving.
Thank you.
Old Jan 3, 2022 | 07:05 AM
Bfgslkman's Avatar
From: Northern Germany and sometimes Southern Germany
Mercedes E220d AMG Line Estate (S213) and Mercedes E220d AMG Line Cabriolet (A238)
You can reckon with about 1litre per 1000km AdBlu consumption, assuming you have a saloon/estate then there they have a 24 litre tank. The most i have tanked was 21 litres with 450km left so you likely about 18 litres or 18000km. Cab/Convertible have a 13 litre tank.
Old Jan 7, 2022 | 06:26 AM
ZAHIDW204's Avatar
mercedes w204 c200 2.2
Repaired twice
I have had the same problem fixed twice both time the adblue tank needed replacing, the sensor that goes faulty cannot be replaced instead the whole tank needs replacing, costs around £1750 each time
Old Apr 9, 2024 | 11:13 AM
helpplease's Avatar
e220d
please can you help me regarding this issue? what was the set back Was it expensive? literally exactly the same thing today happend to me. Please help 🙏
can I still drive the car If I’m putting ADblue in?
Originally Posted by Shaney75
Hi All,
Old Apr 9, 2024 | 11:36 AM
Shaney75's Avatar
E200 CDi
Fortunately mine was under warranty so didn’t cost anything, however it was the NOX sensor that needed replacement. A few hundred quid minimum.
Old Apr 12, 2024 | 02:04 AM
Gavin5354's Avatar
Mercedes E Class E220d AMG line S213
[QUOTE=helpplease;8952896]please can you help me regarding this issue? what was the set back Was it expensive? literally exactly the same thing today happend to me. Please help 🙏
can I still drive the car If I’m putting ADblue in?[/QUO
Old Apr 12, 2024 | 02:07 AM
Gavin5354's Avatar
I had the same issue a week ago, it turn out to be a blown fuse, after replacing the fuse I had to drive the car for about 20-30 miles and it worked again.
Hope this helps.
Old Oct 29, 2024 | 11:38 AM
Louise21's Avatar
Hope this helps.
could you tell me where this fuse is? Getting the same “cannot read as blue level” message myself and can’t seem to find this fuse.
