Premium Burmester with added DSP Amplifier
Music to my ears, I finally added a Musway M12, 12- channel Class D Amplifier with 16- Channel DSP. They have a plug & play wire harness that connects directly to the factory harness. I have been researching for a long time and settled on this brand because they had an option for a Bluetooth module so you can manage the amplifier via an app on your phone.
I communicated with Steve from Allwoods Audio on Ebay from the UK for a couple of months. He was very knowledgeable and helpful. He has the same car and prewired, tuned and tested the amplifier prior to shipping it out. I purchase the Musway M12 DSP amplifier, the wire harness & power cables from him
Using the existing factory speakers and adding overhead tweeters, I am blown away by how much more amazing the system sounds. Having the ability at my fingertips to tune the amp on the fly is fantastic. You can make adjustments and save it as a different setting. So you can do one for Bluetooth, another for Carplay/Android Auto, and another for Satellite Radio.
Below are photos and step-by-step installation. Unlock boot/trunk and doors. Make sure you disconnect the positive/red battery terminal cable prior to installation.
Musway M12 box
Power connection kit
Unboxing
Unboxing, amp & user manual
Mounting plate
USB cable, fuses
Ports and connection points
Vent
Bluetooth module for app connection via phone
Wire harness, I added 2 addition channels with overhead tweeters
Allwoods info
Boot/Trunk trim for removal
Factory Bermester Amp on the left of my car, unscrew 4 nuts to get to the purple amp connection
Fuse box on the right of my car
Fuse box, on the right in my car, this is the top of the fuse box, remove the bottom screw and remove the fuse box
Fuse box, remove the nut holding the red power cable
Factory Burmester Amp, remove purple harness connection
Factory Burmester Amp, after removing purple harness connection. Connect to Amp harness, then connect the other end of am harness to factory Burmester amp
Ground/negative chassis connection, remove nut
Ground/negative chassis connection. After removing cable, add negative wire from amp and tighten nut
Musway M12 box
Unboxing
Mounting plate
USB cable, fuses
Vent
Allwoods info
The following 3 users liked this post by kingscorpian27:
Musway M12 box
Unboxing
Mounting plate
USB cable, fuses
Vent
Allwoods info
Musway M12 box
Unboxing
Mounting plate
USB cable, fuses
Vent
Allwoods info
Factory Burmester amp reinstalled with harnesses connected
Musway M12 installed under storage compartment in the boot/trunk. Bluetooth module connected for App control via cell phone
Musway M12 installed under storage compartment in the boot/trunk. Bluetooth module connected for App control via cell phone. USB cable connected for Laptop
OEM Burmester Overhead tweeters
Musway app,
Musway app
Musway M12 box back with specs
Fuse box, Orange Amp power wire connected to red fuse box wire.
I just added a quick video with my dash cam in 720 due to size limit. Please listen and be the judge. The 1st couple seconds is the stock Burmester then the 16 channel DSP amp is turned on via Bluetooth.
Frank Rizzo (07-05-2022)
I have never personally heard the Burmester 3D system, however I am pretty certain it does not sound as great as mine does now with the Musway DSP and added tweeters.
The following 2 users liked this post by kingscorpian27:
La0laEsMia (11-20-2023),
Nicholi2007 (11-20-2023)
Can you stream in Apx HD? I love the sound of the Burmester, but scrolling through a large Flac collection can be quite tedious with the onboard player. The back button doesn’t take one back to the last spot in their music file, rather I have to go through a tedious process of selecting the music source, then folders, and start scrolling from the beginning after each song selection. I would love to stream lossless music straight to the speakers.
Only the Burmester 3D has the overhead tweeters. My W213 E300 Luxury Model came with Burmester Premium. I added the OEM overhead tweeters and the Musway DSP amplifier I detailed in the original post.
Engineers are usually at the mercy of what marketing wants for the general public. That's a pricey amp
but I believe it. Custom tuning is the way.
Below are the part #’s and prices I paid back then. Remove the sunshade holder and replace with these part. If not, it will cost a whole lot more to get the entire overhead console that accommodates the overhead tweeters.
213-820-10-02
Speaker
$63.44
2 needed
$126.88
000-690-06-00
Speaker Grille
$157.95
1 needed
$157.95
I use Apple Lossless code (ALAC) exclusively, I stream via Bluetooth or connected via Apple CarPlay, sounds absolutely amazing.
213-820-10-02
Speaker
$63.44
2 needed
$126.88
000-690-06-00
Speaker Grille
$157.95
1 needed
$157.95
213-820-10-02
Speaker
$63.44
2 needed
$126.88
000-690-06-00
Speaker Grille
$157.95
1 needed
$157.95
I doubt that I’m going to install tweets into my roof. But how did you connect them to the head unit? Are there wires already in the roof?
I agree with you that the lossless music still sounds great over lousy Bluetooth, as somehow the lousiness of Bluetooth is not nearly as bad as mp3s lousiness. I enjoy the convenience of the music in the car without the need of my phone, I really hoped to figure out a way to make the back button go back into the last folder I was in.
🔥 @kingscorpian27 Thanks for the part numbers! You're the man.
Once I installed the DSP amplifier and had the left and right on their own channel, the difference in sound is amazing. I have them tuned that I hear crisp clear vocals and highs through them with the door speakers/tweeters in the foreground.
Nicholi2007 (12-07-2023)
FYI, unless you run direct wires to the overhead tweeters, they are useless because you’ll be unable to hear them if you slit the dash speaker wires. I initially did that and couldn’t hear them unless my ears were just about right by them.
Sounds like a very immersive experience! Thanks for all the info.
I can see that in order to achieve equilibrium. I've never run tweeters in a roof before. Headliners can be tricky. I have several Mobile Fidelity Sound Lab Gold CDs that I would love to hear with this system.
It actually wasn’t difficult at all and well worth the effort getting it done. My first car in 30 years that I have kept for more that 2-3 years. This was a P3 optioned car with Distronic Plus semiautonomous driving system. I have also added quite a bit of software upgrades too to keep me interested in it. It’s in its 7th year with only 38 K + miles on it so will keep for a minimum on 10 years. Just added a quick video so you can listen to the difference. Also limited to dash cam sound.
