E-Class (W213) 2016 - 2023
Software & hardware mods
Old Sep 6, 2022 | 07:58 AM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
Here is my beloved 2017 E300 Luxury model with P3 package and just about every option checked
Software
1. AMG track pace, drag race
2. Multicolor 64 colors ambient lights
3. Extended voice command
4. Energizing Comfort
5. Cluster to AMG E63s type, AMG Up logo
6. Single touch turn signals change 3 flashes
7. ECO start-stop default OF/memory
8. Speed limit unlock to 200 MPH
9. Enable Intelligent High Beam Plus Activation/ multibeam lights on your vehicle.
10. Enable 360 camera at all speeds
Interior
1. 3D LED rotating tweeters
2. LED front and rear turbine air vents
3. Front overhead tweeters
4. Studded gas/brake pedals
5. Musway M12 Class-D channels and an integrated 16-channel DSP amplifier with Bluetooth adapter for full cell phone control
6. Carbon fiber type center console overlay
7. Night vision 2K front dash cam with HD rear. Front is built into rain sensors/Distronic camera enclosure. Auto on as soon as the car is opened and auto off after a couple minutes when car is shut off and driver door closed
Exterior
1. Custom-ordered 17" aluminum forged rims in Gunmetal gray and polished aluminum finish
2. LED center caps when in motion with MB logo always in the upright position
3. Alloy Gator rim protection
4. Red painted calipers with white Mercedes Benz decals
5. Mudguards
6. Body-color rear trunk spoiler
7. Body-color roof spoiler
8. Red spots graphics
9. Tailpipe splitter
10. Windows rain deflectors
11. 50% Ceramic tint all the way around except windshield including panoramic sunroof
12. All 4 doors projector lights with logo & Mercedes-Benz
13. Chrome door handle bowl cover trim
Side view showing sports graphics & window rain deflectors
Custom ordered 17" aluminum forged rear rim, mudguard ,red painted caliper & white Mercedes-Benz decal with Alloy Gator rim protection
Custom ordered 17" aluminum forged front rim, mudguard ,red painted caliper & white Mercedes-Benz decal with Alloy Gator rim protection
Body color roof spoiler
Logo & Mercedes-Benz projector lights
Night vision 2K front dash cam, side view inside
Night vision 2K front dash cam, rear view inside
Night vision HD rear dash cam connected to the front
Night vision 2K front dash cam, front view outside
AMG cluster classic mode with Speed limit unlock to 200 MPH
AMG cluster classic mode with Speed limit unlock to 200 MPH. Additional AMG Performance
AMG track pace, drag race warning
AMG cluster Sports mode
Dynamic Select, Engine data
Dynamic Select, Vehicle Data
Dynamic Select, Dynamic Data
Track Pace, Telemetry
Track Pace, Lap time
Dynamic Select
Dynamic Select
AMG log at startup on center display
Carbon fiber type center console overlay. LED front turbine air vents
Multi color 64 colors ambient lights & LED front turbine air vents
Multi color 64 colors ambient lights & LED front center turbine air vents
Multi color 64 colors ambient lights & LED front turbine side air vents in red
Multi color 64 colors ambient lights & LED front turbine side air vents blue
Rear LED turbine air vents
Musway is particularly known for building elegant and well-thought-out DSP amplifiers that can be controlled via a smartphone app and beautiful designs. The new M12 joins this tradition with an impressive number of 12 Class-D channels and an integrated 16-channel DSP. It appeals to those hi-fi fans who want to be able to individually tune their complex loudspeaker system in the vehicle for the best possible playback and at the same time be able to control it easily without complex cabling or the installation of several devices.
For optimal sound tuning, a high-quality input section is required, which receives the audio signals from the source. The M12 therefore has a large number of low-level and high-level input connections. There are not only 6 pairs of RCA inputs and an AUX input, but also 12 pairs of high-level inputs that can pick up signals from the speakers. They can withstand a very high load with 20 volts RMS and are used when a complex factory system is already installed in the vehicle. Of course, the high level signals fed in are protected with EPS so that no errors occur in the diagnostic system. An optical PCM input with 192 kHz and 24 bit is available “On Top” for hi-fi connoisseurs. The optional BTS-HD dongle enables HD audio streaming via aptX codecs (576 kBits, 24 bit, 48 kHz).
While the high-end processor supplies the 12 channels internally, the DSP also provides 4 freely configurable RCA preamp outputs. These can be assigned to external purposes and open up many expansion options. This means that further amplifiers can be included in the DSP performance, for example powerful mono amplifiers that are better suited for controlling subwoofers, for example. The Musway monoblocks ONE600 or ONE1000 are particularly suitable for this. The woofers under the seats or in the footwell, which are often installed in a twin pack at BMW or Mercedes, can be optimally fired with it.
The heart of the M12 is the ADAU1452 processor from Analog Devices®, which is highly valued by audiophile connoisseurs. With the easy-to-use PC software, it can be configured perfectly and in real time via USB. With the optional BTA2 dongle, the DSP can also be controlled with the new "Tunest" app using iOS or Android smartphones (see app store).
• Intelligent High Level Input (Error Protection System)
• Start-Stop ready, Auto Turn-On
• Burr-Brown converters (PCM3168A) and Analog Devices DSP (ADAU1466)
• Dual 64bit, 295 MHz DSP technology, controllable via new V3 PC software or V3 App
• Soft-Clipping (power attenuation) in 2 Ohm operation
• Signal-to-noise Ratio ≥95dB
• Frequency Response 15 Hz – 22 kHz (-3dB)
• THD ≤0,05% (1 kHz, 4Ω, 90% Power)
• Separately controllable input sensitivity (Channel 1-6, Channel 7-12, AUX), Clipping LEDs
• External Bluetooth® USB-Dongles (BTS & BTA2) for Audio Streaming & App Control (optional)
• Digital remote control (DRC1) with OLED display for controlling various DSP functions (optional)
M12
12-CHANNEL CLASS D AMPLIFIER
WITH 16-CHANNELL DSP
@ 4/2 Ohms 85/120 Watts RMS per channel*
@ 4 Ohms bridged 240 Watts RMS per channelpair*
12 x High Level Input 8 – 24 V RMS with EPS
6 x RCA Low Level Input (RCA) 2 – 6 V RMS
1 x RCA AUX Input/Stereo 2 – 8 V RMS
1 x Optical Input/Stereo (PCM, 192 kHz / 24 bit)
4 x RCA Pre-Amplifier Output (configurable via DSP)
12 x Loudspeaker Output amplified
Dimensions: 340 x 48 x 171,5 mm
Old Sep 7, 2022 | 02:48 AM
JakeW213's Avatar
W213 220d from 2016
Very very nice upgrades… I like everything, except the red styling. Keep the red calipers - get rid of the decals and switch aloygators to ones that matches the rim color(then it actually looks like you get an inch more in rim size)
Old Sep 7, 2022 | 02:28 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Xtra custom
this is a lot of super nicely executed mods... almost unbelievable it is possible
Where did you find the ways to implement these mods ? Do you have a source or a thread to work out all this magic?
Old Sep 7, 2022 | 07:27 PM
Thank you, noted.
Old Sep 7, 2022 | 07:34 PM
Thank you. All hardware are done by myself except for the window tint and software done remotely. I purchased a MB type diagnostic tool and have a contact in Singapore who has a professional Automotive modification business. I can assist you with instructions and information on whatever needed. Please contact directly in the messaging here.
Old Sep 8, 2022 | 10:16 AM
sabre3's Avatar
E300 4matic
Where did you get the led turbines?
Old Sep 8, 2022 | 10:45 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
same here, the red (design) doesn't go with the car IMO
then again; opinions are like assh*les ; everybody has one and they're usually full of sh*t)
Old Sep 8, 2022 | 04:35 PM
Front center and front sides are all OEM, rear is aftermarket because not available OEM. All wires and modules to integrate are aftermarket
Old Sep 8, 2022 | 04:46 PM
Yep, I have received many many compliments as well too. Just like I would never have a black car or night package 😆. That’s why we all if and when possible personalize to our liking. Thought of changing the color of the AlloyGator to a gunmetal gray as well. The lip of the rims are polished aluminum so would be off for the lip but matches the spokes.
Old Feb 24, 2024 | 02:53 PM
bertoE300's Avatar
2017 E300
I live in New Jersey and have been trying to get the multi color ambient lighting
I’ve been trying to find a way to get the multi color without spending upwards of 600 i want to do the same mods with the vents but not before i do The update can you point me in the right direction. I’m new to this forum and was unable to send you a message directly so apologies if I sent it in the wrong place
Old Feb 24, 2024 | 03:52 PM
There are a couple different vendors that advertise their services on this forum that does the coding for multi-color led lighting. Some will sell you the hardware needed, or point you where to do so and there is one that will rent it. Without the hardware to connect to your computer and car, the coding cannot be performed.
The vents except for 2 rear ones are OEM on my car, there’s the less expensive aftermarket options out there as well. Tried to direct message you, however it said you were either not allowed or not accepting any. If you check your profile and can send a direct message I can provide more information I’m not allowed to mention here.
Old Feb 24, 2024 | 06:18 PM
bertoE300's Avatar
2017 E300
What’s the cheapest route I can take to just get the ambient lighting menu, I know I need a software update but dealers in my area won’t do it, I saw benzNinjas website and It seems like a bit much just to get a updated menu. I’m unsure why my account won’t take messages but I appreciate the response
Old Feb 24, 2024 | 06:42 PM
No dealer will do it, has to be a specialist vendor. I have not seen any company locally with their own hardware that provides this service. So with that said, you’ll either need to purchase your own or rent. I personally purchased my hardware for $600 because I knew I would be using it for multiple software upgrades and additional features. No cheap options getting it done. I have spent thousands on all my software upgrades and new features. My next venture is MBUX interface and software upgrades. That’s quite expensive and technical challenging for changing the hardware.
Old Feb 24, 2024 | 06:54 PM
bertoE300's Avatar
2017 E300
I really appreciate the insight . And apologies for asking so many questions, I’m looking into buying the hardware since it seems like the best option. Did you have to buy the hardware then pay someone to code it or you did it yourself. And is there any hardware you recommend
Old Feb 24, 2024 | 07:22 PM
bertoE300's Avatar
2017 E300
What hardware is needed and after you bought the hardware did you pay someone else to help you with the coding
Old Feb 27, 2024 | 10:57 AM
Please message me directly, thank you
Old Feb 27, 2024 | 11:27 AM
Alberto NJ E's Avatar
2017 E300 W213
apologies for some reason my account cannot do this if there’s any chance you can email me my email is Hothy345@gmail.com
Old Feb 27, 2024 | 01:26 PM
ua549's Avatar
You have to enable messaging in your user profile.
Old Feb 27, 2024 | 02:00 PM
2017 E300 W213
yes i tried looking for a setting was unable to find it
Old Feb 27, 2024 | 02:08 PM
ua549's Avatar
Click the settings cog on upper right to open "Your Control Panel".
Click edit options..
Scroll down to messaging & notifications.
The private messaging panel allows you to select options.
Old Feb 27, 2024 | 02:25 PM
2017 E300 W213
I have it enabled I believe i need To have 3 or more posts to be able to message unfortunately, i made A new account thinking it was an activation issue but it isn’t
