Wagon ONLY question:
Stiff Run Flat Tires.
Lusting for Michelins AND a small spare kit like this:
Looking under my trunk floor, there is a well for a spare, but an aluminum bolted on stringer seem to be blocking
full access.
Question: Is the stringer structural, OR only needed for kiddie seats in the back?
I will never need the 2 backward facing jump seats, would like to remove them but keep the flat floor.
Any ideas how fo fit a spare and jack back there, remove the jump seats and keep the floor?.
Made up some 10 inch wide boards to fit in the hole with some support feet. Covered the boards in carpet and then cover the whole floor with a flat rubber mat.
Lots of extra room under the boards where the seats were.
Just be careful removing the seats, take a video of how you do it so you can restore the seats before you sell the car.
Ivan, was it easy to remove the seat pads? Wass it obvious how to do it. Thanks phil
Better and better?
(I know, leading question
Noise wise, I believe it is a wash. The new Michelins do have a hum, but you get used to it, and then you don’t notice it at all.
In the meantime: Does the used Run-Flats have any value: They were mounted just before I got the wagon, about 4,000 miles on them: I hate to throw away expensive tires, but I could..
How much are the Michelin's, $300 each?
Pretty sure those of us with ATs are out of luck, though…IIRC we have a big battery under there.
My W213 came equipped from the factory with AMG 20 inch wheels even though it's a standard E200d.
The interior is AMG as well as the body kit. Not AMG or sport suspension.
I removed the AMG wheels and replaced them with W222 (S class) 18 inch staggered.
Running Michelin PS4s at the front and Pilot super sports at the rear. Not Runflat.
I carry one of those compressed cans with sealent - just in case.
I do many 2000K trips in the car. If I have a puncture or tyre failure with the runflats miles away from a fair sized city I'd be in a fair amount of bother. 20 inch wide runflats don'tgrow on the local tree.
Still if I could put a spare in I would and get a new set of tires.
I personally like to buy a full-sized spare, and use that in the tire rotation, so that the wear on all 5 tires (4 on the car and the 1 spare) are even. Of course if we have the staggered tire sizes like in the 20”, we would not be able to do the rotation, as outlined above.
