E-Class (W213) 2016 - 2023
Help! Can't Reset Service Indicator
Old Jan 20, 2023 | 03:10 PM
Long Islander's Avatar
2018 E400 4matic Wagon
I have the instructions for resetting the service indicator and I've done this successfully before, but I seem to be stuck this time. I can't get into the workshop menu. When I'm in the trip menu and I hold the back button for 1.5-2 seconds and then press on the navigation pad, I don't get the workshop menu with "vehicle data," "dynomometer test," "lining change mode, "ASSYST PLUS" and "head-up display." What am I doing wrong? When I start the car or put the ignition into position "2" I get a display that reads "Service A3 Due."
Old Jan 20, 2023 | 03:54 PM
konigstiger's Avatar
'71 Pinto
How about this...
Old Jan 20, 2023 | 04:45 PM
How about this...
Those are the instructions I used. On step 5, I don't get the workshop menu. Could it be that I get a message stating that "Service A3 Due" in the nultifunction display when I switch on the ignition?
Old Jan 20, 2023 | 05:04 PM
superswiss's Avatar
2019 C63CS
You are likely in the wrong ignition position. I always get confused. With the foot off the brake you can press the engine start once, and then another time. I don't remember which of them is actually position 1. But try first with pressing it once. If that doesn't work, press it again. At least that was my issue I had in the past, other than forgetting to select trip and total distance.
Old Jan 20, 2023 | 05:43 PM
Thanks, I'll try it again with the igrition in various positions to make sure I'm in the right one. I recall a couple of years ago, it took me almost an hour but in the end, I succeded in resetting it.
Old Jan 20, 2023 | 08:30 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
When I do the reset, I close the door, hit the ignition once, but foot not on the brake ,and go to home button and go to trip.
Make sure total mileage is displayed
Hold home button for several seconds and then press scroll button - maybe twice
Vehicle data, Dynameter test, Brake pad replacement and Assyst Plus come up
Scroll down to Assyst Plus
Switch on ignition to activate
Scroll back to Service data, full service and scroll down to Full Service
Confirm full service
Grade Oil 229.5
Yes
Confirm
you are now reset
Hope this helps
Old Jan 21, 2023 | 08:07 AM
I don't know how I did it but it worked! I think the key is when you're in the trip menu and hit the back button (step 5 in Konigstiger's post) to very quickly press the center button on the navigation pad. That gets you into the workshop menu. If you're not in the workshop menu, start all over again. It's not easy, and it's likely to take several tries. Many thanks to those who responded to my post.
Old Jan 21, 2023 | 08:50 AM
DFWdude's Avatar
2016 E350 Sport
Yep, that's the trick. I didn't post earlier, because I don't have a W213, and assumed the navigation pad would be different. But on my W212, that's how it works, (using the "Answer Phone" button on the wheel instead). Less than a second does it for me.
