Speed limits insane!
BUT
In June there was navigation update and since then the speed limits showing in the instrument cluster and the speed limit assist are wrong. The road I live on has a speed limit of 45 mph but the car reads it as 15. I took a trip last week and every time I had to use an exit to get on another interstate it would read the speed limit as 80 mph. I can be driving in a construction zone on the interstate where the speed limit drops to 55 mph which the car will adjust to but then all of sudden a mile or two later it will shoot up to 70 mph without any speed limit sign indicating a speed change.
is anyone else having this problem with the last update?
. But so far haven't caught it showing the wrong speed limit.It sounds like the speed limit data is wrong in the latest map update for your region. Generally, the speed limit comes from the camera when it "sees" speed limit signs, but if it hasn't seen a speed limit sign for a certain amount of time, it falls back to what the map data says for the current road you are on. So it sounds like whenever it decides to fall back to the map data, the speed limit it gets from the database is wrong.
BUT
it was over the air
I was traveling on the highway, and the speed limit was 65mph. The car suddenly started slowing down pretty quickly, because it somehow thought the speed limit had changed to 25. There were cars right behind me, and I found it to be unsettling.
If there's no way to update the car so that certain places aren't showing dramatically lower speed limits having this feature active is downright dangerous.
I wish I could figure out exactly what causes the phantom quirks (sometimes it's a badly-placed and/or -designed road sign - those I get), but I've just learned to ignore them. I can anticipate the few regular ones and the unique ones are fairly rare. I still like the feature and use it + ACC almost all the time, even on busy city streets.
If I don't happen to know the current speed limit, I still like to see the car's opinion of the speed limit on the dash. I sometimes find myself checking the dash when driving another vehicle that doesn't have this feature. Having the car automatically update the cruise control speed is somewhere between useless and dangerous for me.
