Wondering how long my Turbo will last on my 2017 E300 2.0 (w213)
#201
Dude why are you still commenting and talking to your self LOL. I've dropped the thread.
That NHTSA bulletin you read was made at the beginning when people first started to realize the C Class and GLC class Mercedes were having engine failures. That does not account for all of the cars AFTER the bulletin came out. You can literally find threads by other users all the way to 2019 with piston failures. All you have to do is use Google:
2018 E Class
https://mbworld.org/forums/e-class-w...23k-miles.html
2019 Sprinter M274 engine
https://sprinter-source.com/forums/i...hreads/108609/
2017 E Class
https://mbworld.org/forums/e-class-w...re-advice.html
All with relatively low miles. One of the engine failures was at 45,000 miles. Not sure what still isn't clicking inside of your puny little brain. Imagine all the people with engine failures who aren't part of MB World or BenzWorld or any other forums to share their story. I'm willing to bet that we'll still continue to see engine failures with more M274's because people drive their cars relatively less than others, and once they reach that certain milage and their engine does explode, they'll probably share their experience too.
Also - Read this:
https://www.carcomplaints.com/news/2...problems.shtml
You're wrong about Mercedes maybe taking action to fix the wrist pin issues. They aren't doing jacksh*t.
You're wrong. But if you must hear that you're 100% right, then I'll say you're right and I'm wrong. Just let it go. No one cares.
2018 E Class
2017 E Class
Also - Read this:
#202
As a Mercedes mechanic for over 27 years I can tell you that these piston failures are few and far between. Out of the thousands of cars I see every year and work on I've only maybe seen two to three each year that had this piston failure. If you think that every m274 engine has the defective wrist pins you are wrong they don't. I just worked on a 2017 E300 still going strong no engine problems at 183,000 Mi and there are many cases with this year model with high models and no piston or engine problems. I agree with this Massimo guy I read everything he said he's pretty much right on target and if you think that every W 213 E300 2017 and up engine will have this piston failure you my friend are wrong once again this is few and far between there are plenty of them out there with high miles I see them every day going strong and do not have the defective wrist pins. I work on more e classes and c classes than any other vehicle and I would know. With all respect you are wrong sir not Massimo.
I too have a W213 E300 and it currently has 145,000 miles and not a single issue. So I would be an idiot to say that every engine has defective parts.
I am trying to explain to this guy that it wasn't "just a few M274's" with defective parts and that failed. There are potentially thousands of them out there and we just haven't heard of all of them and not all have failed just yet. But you you are one technician out of how many thousands that only "replaced a few". How many engines were replaced under warranty throughout for engine failures? I personally know an MB tech in Greenwich CT and in Rockville NY that had replaced M274's left and right. So while you might have replaced only a few, other techs around North America and throughout Europe replaced the rest.
To my other point, our friend Massimo here believes that it was just certain engines on C Classes and GLC from 2015 to 2016 with certain engine numbers which also is not the case. There have been reported issues with M274 engines up to 2019 with wrist pin//piston failures across the entire M274 platform. So E Class, C, GLC, GLE, Sprinter, etc. So that is the entire take of this thread. While i have provided threads from other users with those unfortunate issues (including my self who has a cracked piston due to these loose parts), he still disagrees and doesn't seem to believe it. Almost like he thinks his car will blow up so he has to keep reassuring himself that it won't happen (which is more than likely won't). Unsure what isn't clicking here.
#203
Well you sure are making it sound like it's all the m274 engines, putting fear into people's hearts again this is very few and far between I know Mercedes mechanics across the US and all agree with me and Massimo is right on the models the engine number makes Etc he's on target with that as well, we're just not seeing that many and neither are my friends across the US and Europe is not having these problems you're wrong again Massimo answered that question several times for you seems that you are hard-headed and are the one who's not getting it.
#204
LMAO- thank you!!
Just ignore him I do now- he's a true moron and just because one of hes Mercedes had this issue he is apparently really hurt by it and thinks this affects the majority of people with this engine, and it does not!!
You know we all had this one ex-girlfriend that was abused by her boyfriend and thinks every guy will be the same, (damaged goods), that's what he is LMAO!!!!
NO matter what you say- he will remain a moron Just ignore him!!!
#205
Received 1,714 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 (W212 @100K), 2015 ML350 (W166 @96K)
How do should MB have done to be on the right side of the customer<-> manufacturer relationship? Here is the answer -> https://www.caranddriver.com/news/a6...cement-recall/
I am not suggesting replacing ALL the engines, but those that really failed. If it is random failures, so be the repairs
Nobody addresses why the V6 and V8 do not show the same issue. From the technical side, I would love to understand why the V6 and V8 of the same generation are more robust to "gasoline", "oil rating", etc.
#206
LMAO- thank you!!
#207
But if you want to side with Mr. "your engine will blow up if you put 89 octane in your car once" (massimo) then go right ahead.
CarFan1 (Yesterday)
#208
Received 1,913 Likes
Maybe Nissan subcontracted some of the M274s to Hyundai/Kia. (Just trying to stir the pot a little .)
The following 2 users liked this post by JettaRed:
Billyismyname (10-02-2024),
juanmor40 (10-02-2024)
#209
Also Volkswagen had similar issues. I never really liked V4 too be honest, but that's the way there all going now! :-)
#210
Received 3,805 Likes
MY'14 W212 M276 3.5NA @60kMi
Small turbos are good/bad for multiple reasons.
We are stuck in our own reality.
Open minds are few.
Open minds are few.
#211
Before I bought my 2019 E300 used, I did plenty of research on the piston issues. My theory is that the 6 and 8 cylinders are not push as hard as the 4. In my opinion, the 4 cylinder is fine for everyday driving but when one drives the car like he stole it, it will have issues. Everything engine has a weak design point, when push to the limit continuously or when the engine is chipped to increase torque, that is where this weak area will fail. Pretty safe to say, most of the 2019+ E class is free from piston failures.
Billyismyname (10-03-2024)
#213
I don't think comparing the M274 with the M276 and M278 (and others) is a valid comparison since those engines (M276 and M278) are of the same "family" and generation, and the M274 is not. I just don't know enough about the M274 to make a statement that it is of the same design and parts as the 6 and 8 cylinders.
#214
Not sure 4-cylinder engines are pushed harder, but maybe. As I've mentioned before, I have a 2004 Audi TT 225 with a 1.8T engine with over 250,000 miles. It's been Revo chipped over 90% of that time. Same K04 turbo. Does she run like brand new? No. But she still runs well enough.
#215
@JettaRed I asked to point out the obvious: "same engineering department", it does not matter if MB has 2, 3, 4, 5, 6, 8 or 12-cylinder engines. All of them will use the same gasoline = random sources in different countries by owners with random habits.
Billyismyname (10-03-2024),
juanmor40 (10-03-2024)
#216
The issue with the engine failures is that the wrist pins were made not-to-spec, which in turn had play/lose tolerances with the pistons. Once the already out of spec wrist pins wore out/over heated, they snapped, cracked, made the piston slap the cylinder walls, etc. Looks like most of the newer M274's don't have any problems like my current E300. However, there are reports of MB 2018-2019 YM having engine failures for the same thing.
The "new" issue people seem to have with the M274's is the chain/rattle problem and the camshaft backing plate rotating from the actual camshaft. I've been seeing a lot of those issues lately the more people put miles on their cars.
#217
If reliability is one's top priority, then Japanese cars are the way to go. I purchase my Mercedes knowing it is less reliable, that is a tradeoff I am willing to take. My hope was not to get a lemon like the wrist pin issue or the crack piston issue but I have had lemons from other European manufacturers as well. Out of the German big 3, Mercedes in my opinion is the most reliable.
#218
#219
In my opinion the E-class is the most reliable Mercedes made there's a reason why Germany uses them as taxi cabs
#220
As for your Japanese car statement, you're 100% correct. German cars are over engineered and that's not always a good thing. More engineering = more things to fail. Although Japanese cars are starting to go that route as well.
I've owned several Lexus's and never had a single issue. In fact, Lexus just scored most dependable car brand second year in a row. Don't know how BMW made that list at 3rd place, but I can vouch for Lexus's all day long.
#221
Audi is the worst then BMW in my opinion. I've owned several Audi's and all had major oil leaks. My buddy is a master tech at Audi and loves his job because he gets paid hourly to work on newer Audi's that have major issue after issue. BMW's are more solid, but still prefer Mercedes.
Billyismyname (10-04-2024)
#222
I concur that Audi has its problems. I think cars of the early 2000s were good, especially the transverse mounted 1.8T, but they started going downhill with the 2.0T engines having all sorts of mechanical issues. The 1.8T was plagued with oil sludge problems with people running long oil change intervals and/or using unapproved engine oil. But if you changed the oil every 5000 miles or less with an approved oil, you were good to go.
I just think the whole VW group has it's issues other than the Porsches. I had a lemon 2017 GTI that had to get it's timing chain replaced 3 times. Car had less than 20,000 miles.
#223
@JettaRed Are you trying to start another argument with the oil change intervals? LOL (I agree)
This is an interesting video from Hoovie about Toyota quality changing. Not the first time I've heard that about Lexus' 10 years ago and now.
#224
Nope, but I'm not going to back down from the tried and true. Sometimes there are lemons that no amount of maintenance is going to fix (I had a 2005 Audi A4 1.8T that was an absolute piece of crap), but if you have an otherwise good car, it's prudent to do what you can to keep it that way. There are enough expert mechanics that will tell you that a 10k miles change interval on any engine, modern or otherwise, is a bad idea.
https://youtu.be/sX6dp3Z8XJ4?si=Ki1BjOnURoC9f0Qt
All quality is going down. No matter the manufacturer. Mercedes is in a decline for the better half of the past 10 years in my opinion.
#225
The Japanese are master at copying technology, they build their brand on reliability. They would let the Germans try out a new technology for a few years and once most of the bugs have been worked out, they then modify on the design with reliable in mind. The turbo charged engine is a good example.
