E-Class (W213) 2016 - 2023
Fault code U010B85
Old Apr 4, 2025 | 11:02 AM
Mark Davidson's Avatar
Mercedes E220d w213
Fault code U010B85
Hi any one got a idea what this means fault code is U010B85 it says as below
Communication with the exhaust gas recirculation controller (cylinder bank 2) has a malfunction
There is a signal above the permissable limit value
how would I fix it
Thanks Mark
Old Apr 6, 2025 | 11:09 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
how would I fix it.
Thanks Mark
This fault's on a DIESEL engine correct?
Can your scanner interact with that EGR Module at all ?
Ultimately this may be related to back-pressure from a dirty DPF...
Old Apr 9, 2025 | 07:41 AM
Mercedes E220d w213
Yes diesel 2.2d engine.. the garage replaced my Egr valve under warranty but the ligh came back on !
Old Apr 9, 2025 | 03:15 PM
trigital's Avatar
W213 All-terrain
There are two EGR systems on your car....
Old Apr 9, 2025 | 05:17 PM
Mercedes E220d w213
The code U010B85 says that communication with the exhaust gas recirculation controller ( cylinder bank 2 ) had a malfunction. There is a signal above the permissable limit value
Old Apr 9, 2025 | 05:19 PM
trigital's Avatar
W213 All-terrain
Yes, but your car has just one bank....
Old Apr 10, 2025 | 12:47 AM
one new EGR under warranty: no difference.
There are two EGR's...
Modern Bosch 4 cyl. ECU can track bank1 and bank2 for best emission management. Engine doesn't need to be split in 60° V.... 180° is a line.
Again this has something to do with back pressure from clogged DPF.
Check the harness for factory painted GND post, interact with module them tackle pressure issue.
Old Apr 10, 2025 | 04:46 AM
trigital's Avatar
W213 All-terrain
More likely is about one High pressure EGR that return the gases before the DPF and a low pressure EGR that's use the cleaned gases behind the DPF.
I would start with a real diagnosis.
