E-Class (W213) 2016 - 2023
Replace sparkplugs at 5 year mark with 27k miles?
Old Apr 20, 2025 | 01:34 PM
ryuan1688's Avatar
2019 E300
Hello, does anyone know if the spark plug replacement should be done at the 5 year mark if I'm only at 27k miles so far? I saw on the service schedule that they are marked for replacement at the 5 year / 50k mile mark, but I'm debating if I should wait until I hit 50k. If yes, does anyone have a link or part number where I can order them? I'm going to an independent shop to perform my next A3 service and might try to replace the spark plugs myself. Thanks in advance!
Old Apr 20, 2025 | 01:40 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I would replace them now. Plugs can corode over time and cause poor detonation in the combustion chamber. Low mileage may even make it worse since it's sitting for longer periods of time and may not be driven to normal operating temperature on short trips. Low mileage can be considered abusive and harsh conditions rather than the other way around.
You should be able to call any dealership parts department and get the PN for your specific car. Good luck!
Old Apr 20, 2025 | 03:08 PM
W205C43PFL's Avatar
Agree, just get OEM plugs and beware counterfeit, MB plugs comes pre-indexed.
Old Apr 20, 2025 | 05:29 PM
ryuan1688's Avatar
2019 E300
Thanks guys, I'm going to buy the tools and replace them myself. Got a quote for $350 in Northern California at an independent shop so I'll save ~$300. Looks like the MB part number for the spark plugs is 2701590700. Does anyone happen to have the WIS documents for both removing the ignition coils and spark plugs?
Looking at my engine number of 27492031781871‬ that I got from a VIN Decoder, I believe I should be trying to find WIS documents that are for "Engine 274.9 in model 213"?
Old Apr 21, 2025 | 08:02 AM
ua549's Avatar
My car has very low mileage - 3k per year. As such, I follow the maintenance schedule based on time, not mileage.
Old Apr 21, 2025 | 09:16 AM
BoMB's Avatar
2018 E300 4Matic Sport
Parts break down, corrode, wear and tear -- due to use (mileage) AND time. Perhaps it's safe to say, "whichever comes first" so to speak.
Old Apr 21, 2025 | 09:29 AM
streborx's Avatar
Top Answer: 1
G550
I'm at 25K miles at 5.5 years. My driving is a couple trips a week, usually at least 50 miles r/t at highway speed. No indications of abnormal ignition, either in performance, fuel consumption or OBD scans. I plan to change plugs at 40K unless something changes. Of course changing plugs sooner does no harm. Will the OP post some pics of the plugs he removes? We'd all appreciate seeing how they look. I'll do the same when I do mine.
Old Apr 21, 2025 | 10:00 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Spark plugs are a wear and tire item. It makes no sense to replace after only 27,000 miles.
Keep in mind that most other cars the recommended interval is 100,000 miles. MB is half that and at 27,000 miles half that again.
You will find on this forum many who adhere to the MB schedule of time vs. mileage as if it was religious doctrine which by not following your car goes to car "hell".
I prefer a more common sense approach.
Just my $.02.
Old Apr 21, 2025 | 10:33 AM
streborx's Avatar
Top Answer: 1
G550
I changed out my Jeep JK's plugs last summer at 60K miles. Three of the six plugs (Pentastar 3.6L engine) had electrodes badly burned away. No way these were a 100K mile wear item. I'll do them again at 100K miles.
But for the few who remember doing 5,000 mile "tune-ups" -- replacing the points and condenser, along with the rotor (and sometimes the distributor cap), and then setting the timing and dwell -- getting 10K miles from a set of plugs ($0.87/ea. when not on sale) was about what you could expect.
Old Apr 21, 2025 | 10:43 AM
JTK44's Avatar
Yes I remember doing all that, but I remember changing points and rotor every 10K miles not every 5K, but it was so long ago, my memory may not be correct.
I also remember taking out plugs, cleaning and re-gapping and replacing. In those days didn't have the money to constantly be replacing - reusing was the order of the day!
Old Apr 21, 2025 | 11:46 AM
streborx's Avatar
Top Answer: 1
G550
I remember the points being a function of brand. The genuine Mopar points were wasted in 5K, while NAPA points could be filed a bit and were good for another 5K. Aside from that, all I remember is loaning my timing light to someone about 20 years ago and never getting it back. I haven't needed it, and wouldn't be able to find it if I did, but it's the principle (lol).
Old Apr 22, 2025 | 04:18 PM
figuwx's Avatar
2018 AMG E63s Ed1
MB stopped using copper plugs many a moons ago.
Now a days they are on Platinums, Iridiums or Reuthiums and all those metal, none "corrode".
Old Apr 22, 2025 | 07:58 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
For plugs it is miles not time. They energize more than once a cycle, hence the need for replacement every 40 or 50 thousand miles. Less miles, less firing, less wear. Here you can economics, unless you worry that the warranty ninnies will get you.
Old Apr 22, 2025 | 08:28 PM
W205C43PFL's Avatar
I heard MB plugs fires 5 times? Is that true?
Old Apr 22, 2025 | 08:29 PM
W205C43PFL's Avatar
Maybe it was 5 times after all, found this video:
Old Apr 23, 2025 | 06:41 AM
ryuan1688's Avatar
2019 E300
I will be sure to post pictures once I replace them. I need to buy all the tools required first. After watching a few videos online, replacing the spark plugs seem to be a straight forward enough job. I am worried though about possibly breaking a spark plug though if there is corrosion, but I guess that's a bridge I will cross if it happens lol.
Old Apr 23, 2025 | 11:20 AM
streborx's Avatar
Top Answer: 1
G550
There's a difference between "corrosion" and "errosion". Precious metals such as those you list do resist "corrosion" -- that is, reacting with other substances such as oxygen (oxidizing). However, under some circumstances these metals will "errode". Here's a photo of two of the iridium plugs I removed from my Jeep at 60K miles. One was reasonably still intact, while the other had badly eroded -- who knows why. I replaced them with NGKs -- we'll see how they look at 100K.
