Need help with service intervals - spark plugs
Recently purchased a 2019 Mercedes E450 with 80k kms (50k mi). Screen says service b6 due. What is included in b6??? I don’t want to go to the dealer for this. The dealer I bought from just had oil and filters replaced. Some online sources say sparks are due now and some others say they’re due at 100k kms. Can someone please help me out here? Perhaps if you can share an original service interval manual that would be amazing!
thanks
thanks
I believe it used to cost around $1400, mostly because the transmission oil and filter are expensive as hell.
I however change my spark plugs on my E300 every 30,000 miles. Is is overkill? Probably. They don't look terrible when I inspect them, but it gives me an peace of mine when I swap them and I can inspect them to see if there is any oil on them or if they've changed color. They're not too terribly expensive either to change early.
I would highly suggest doing them your self to save you a ton of money. I believe the spark plug service alone at my MB dealership was more than $500 for 4 plugs, i can't imagine what they're charge for the E450 with 6 plugs.
B6 is a B service (new oil + filter + more detailed health check) with additional Air filter replacement, spark plug renewal, brake fluid replacement and sunroof cleaning and lubrication. I would suggest that unless your car is under dealer warranty, find an independent Mercedes specialist mechanic in your town and get them to do it.
