E-Class (W214) 2024 -
Changing oil on 2025 E450
Old Nov 27, 2024 | 08:13 PM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
On my present car, a 2019 E450 I can use an oil extractor through the dipstick to change the oil. The oil filter is easily accessible. Doing it myself saves a lot to time and money.
I have read that the new I6 does not have a dipstick. Does anyone know if the same procedure can be followed with I6 found on the 2024 and 2025 E450's or is draining the oil from below the only way to change the oil?
I am too old to jack up the car and use a mechanics creeper to get under the car to drain the oil.
Many thanks in advance!
Old Nov 27, 2024 | 09:13 PM
W205C43PFL's Avatar
You will need to do it the old fashion way and drain it, there is no other way on the M256.
Old Nov 27, 2024 | 09:19 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I've done it twice already. Not hard, but yes, you have to get under the car. The plastic shroud must be removed (10 screws) to get to the plastic drain plug. It's a large plug with large threads that snaps into place rather being torqued. It's beast to use a large blade screw driver but there is a special tool you can get for it to make it easier. I have it and it does make it easier. Worth it if you are going to do it more than a few times. Mercedes also recommends you change the drain plug. On my first oil change, I reused the drain plug. On the second, I replaced it. The filter is easy to get to. You do have to remove the air intake on the right (as you are looking at it from the front). None of this is hard but it's certainly not as easy as on my W212 using an extractor from the dipstick.
Old Nov 27, 2024 | 09:35 PM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
What about resetting the service meter? Can you shed light on that? I’ve always done my own services. It’s a series of steps on my GL450 and it was always a pain on my old CL500. And maybe a link or description of the drain plug tool you mention.
Old Nov 27, 2024 | 10:53 PM
JTK44's Avatar
I was afraid that was going to be the answer. I have a creeper, but as I posted I am just too old to be going under cars.
Funny thing is that I always used to do it, but once oil changes came down in price to under $30, I said why bother.
Now that prices have gone through the roof, even my Indy guy is $150, I am too old to do it!
Such is life!
Old Nov 27, 2024 | 10:57 PM
liexpress's Avatar
2024 E450
Can I do maintenance/A-B Service myself without voiding the warranty?
Old Nov 27, 2024 | 10:58 PM
JTK44's Avatar
Brings me back to the days of my Fiat 124 Spyder: There were 16 screws holding in place a metal cover plate that had to removed to get at the oil drain plug. I thought only the Italians could design such a system!
  • 10 screws to remove the shroud to get at the drain plug
  • Special tool to remove the drain plug
  • Replace drain plug when you change the oil
  • Remove air intake to get to the oil filter
  • Replace shroud and 10 screws
Now I know better!
Wonder what the dealers will now charge for a simple oil change!
On American cars parts that need to be regularly serviced are easy to get out. Germans can make easy things hard!
Old Nov 27, 2024 | 11:00 PM
JTK44's Avatar
Yes of course: under US law, as long as the required service is done, it does not matter who does it, your warranty is in tack.
Old Nov 27, 2024 | 11:30 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
You can get to the workshop menu by holding the home button on the steering wheel for 10 seconds and then immediately hold the OK button just left of the home button on the steering wheel for a few seconds. That brings up a menu. Just follow the prompts. I use that to get to tha actual oil level gage. I haven't reset the service meter as both oil changes were early at 722 and 5200 miles. I'll bring it in for an A service at 10K.
Old Nov 28, 2024 | 06:33 AM
W205C43PFL's Avatar
Such is life!
You can get to the workshop menu by holding the home button on the steering wheel for 10 seconds and then immediately hold the OK button just left of the home button on the steering wheel for a few seconds. That brings up a menu. Just follow the prompts. I use that to get to tha actual oil level gage. I haven't reset the service meter as both oil changes were early ar 722 and 5200 miles. I'll bring it in for an A service at 10K.
Good info.
Sorry for the bad news OP.
Good idea, since the regular engine oil level gauge is too vague.
Old Nov 28, 2024 | 10:38 AM
Hicksra's Avatar
Thanks for the info.
Old Apr 19, 2025 | 08:38 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
If you do your own service be sure to document including date and Miles. I understand there is a way to make it part of official carfax record.
Old Apr 19, 2025 | 09:01 AM
W205C43PFL's Avatar
Keep the receipt as well. Take pictures if wanted. Curious how you put it in the service records section in carfax?
Old Apr 19, 2025 | 09:43 AM
DFWdude's Avatar
2016 E350 Sport
Is there no way to remove the oil filter, and then siphon the oil through that portal? Vacuum pulls the oil up through the tube. So there's no need to create a seal at a dipstick. I've been doing this with my C/E Class cars for 20 years, and am too old to "Make MB Great Again" by retreating to the Neanderthal days.
I'd snoop around at the dealer to see how they do it. I bet they have a way that doesn't require service from below. Think of the investment they have in their dealer-sized oil extraction systems.
Old Apr 19, 2025 | 09:44 AM
W205C43PFL's Avatar
Sadly, it doesn't work : ( only through dipstick if it has one (in this case, it doesn't) the filler neck won't work : (
Old Apr 19, 2025 | 10:05 AM
JTK44's Avatar
I followed your suggestion on my 2019 E450 and bought a siphon machine that is dual: hand and air compressor as I have an air compressor. I had no trouble using it on my car through the dipstick although it took longer than I expected. Maybe the oil was not warm enough but taking time is not a problem as it was hooked up to the air compressor.
From my understanding on the W214 without a dipstick, it is not possible to remove the oil through the oil filter, as the extraction tube will not go directly to the oil pan.
That means going under the car, removing the protective cover and then removing the nylon oil plug, which should be replaced each time.
I am now 80+ and my days of jacking up a car or driving up ramps, getting under a car with a mechanics creeper, (Christmas present from my wife 45 years ago) removing the protective cover and then the oil plug are over!
Old Apr 19, 2025 | 11:57 AM
Hicksra's Avatar
It only makes sense that using the dipstick you’re going straight into the oil pan where it can be siphoned out. Trying to go through the oil filter housing would not go directly into the pan, but into the oil pump system.
Old Apr 19, 2025 | 01:04 PM
W205C43PFL's Avatar
Precisely, bottom drain it is.
Old Apr 19, 2025 | 01:08 PM
LAZARU5's Avatar
2025 E53 Hybrid
....I am now 80+ and my days of jacking up a car or driving up ramps, getting under a car with a mechanics creeper, (Christmas present from my wife 45 years ago) removing the protective cover and then the oil plug are over!
That's exactly why I am teaching my grandson to do the maintenance on my car which will likely end up being his car.
Old Apr 19, 2025 | 01:12 PM
W205C43PFL's Avatar
Which vehicle though, the E 53 hybrid? With the fast growing technology and hopefully improvement in battery technology not sure if the vehicle will be traded in for something else rather quickly (when it is ready that is)?
Old Apr 19, 2025 | 02:16 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I just had my first A service done yesterday and I saw them do the work. Car was lifted and oil drained from the pan. No extraction method used. They only put 8.5 quarts in when the manual says the capacity is 10.5 quarts. This aligns with my own service notes where I have never drained more than 8.5 quarts. I'm assuming a good bit of the oil stays in the engine unless the manual is wrong. It does seem like 10.5 quarts is a lot of oil.
Old Apr 19, 2025 | 02:19 PM
LAZARU5's Avatar
2025 E53 Hybrid
I probably won't trade the E53. I will need another car for the second grandson.
Old Apr 19, 2025 | 03:11 PM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
I'll completely allow you to adopt me if you'd like!
Old Apr 19, 2025 | 03:59 PM
W205C43PFL's Avatar
Sounds good : )
Old Apr 19, 2025 | 04:30 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I've looked into this and you can provide details of DIY service and even upload receipts but it will now show up on the official carfax report that people will see. Here is link to the FAQ on this.
https://support.carfax.com/article/c...rfax-car-care/
