Took delivery of my All terrain.
Don't forget to post in the picture thread, enjoy in good health! https://mbworld.org/forums/e-class-w...re-thread.html
The door handles only pop out if the car is locked and you approach with the fob. Or, if you have been away for a little while. At least that is what I have noticed. I have on two or three occasions had them close on me when I try to open the door. It was aggressive in a way that made me feel that it would have closed on my hand if I didn't pull away. In any case, a swipe is not the only way to have them push out. You can touch the dimple to have them come out or to have them retract and lock the car. Much more consistent than the swipe which doesn't always work.
she's a beauty. I really like the color choice. I too missed the feature of being able to control the front passenger seat.. Once you drive the car for a bit I'm sure you will enjoy the tech and the ride..In my opinion this car is much improved over the 213..
In the meantime, does swiping the passenger side also bring out the driver side? If so, might be a temporary solution for now until it gets fixed.
Here is what I suggest and it is inexpensive and can be found on Amazpn:
3M Dual Lock SJ3550 1"×6ft Black 1 Pack Reclosable Fastener Mounting Tape Interlocking Mushroom Shaped Strong Adhesive Hook Lock Sticky Tape for Indoor and Outdoor
Hope this helps
Car Knee Cushion Pads, High-density Memory Foam, For Comfort and Pain Relief while Driving (Black, Set of 2) https://a.co/d/3txKZlq
