E-Class (W214) 2024 -
For anyone that had the staggered Bridgestones this is a deal
Old Dec 9, 2024 | 12:52 PM
2012 merc amg's Avatar
2018 S560
I dunno why tire rack is selling the wide rear tires so cheap but it’s a deal. If my car had the staggered 20 inch option with the wider rears I’d probably pick up a spare pair at this price and keep them in the garage till needed. https://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Turanza+T 005&sidewall=Blackwall&partnum=835YR0T005XLBSV2&ta b=Sizes
Old Dec 9, 2024 | 01:53 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
You link doesn't work. Seems incomplete.
Old Dec 9, 2024 | 02:12 PM
W205C43PFL's Avatar
Originally Posted by 2012 merc amg
I dunno why tire rack is selling the wide rear tires so cheap but it’s a deal. If my car had the staggered 20 inch option with the wider rears I’d probably pick up a spare pair at this price and keep them in the garage till needed. https://www.tirerack.com/tires/tires...BSV2&tab=Sizes
It is a spacing issue OP's link opens up for me:
Old Dec 9, 2024 | 04:04 PM
2018 S560
Still doesn’t seem to open up to the tires though. They can be manually entered for the rear size. The tires $104 dollars which is a deal.
Old Dec 9, 2024 | 04:10 PM
W205C43PFL's Avatar
Strange, it opens up directly for me.
Old Dec 9, 2024 | 04:14 PM
W205C43PFL's Avatar
It says 113.47 per tire original price is 561.94, set of 4 is 453.88
It is a good deal indeed, I am in Canada so it doesn't benefit me though, good deal though OP.
Old Dec 9, 2024 | 05:32 PM
nsx78's Avatar
Can someone list the details to search manually? Cant find it. Thanks
Old Dec 9, 2024 | 05:53 PM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
I didn’t see my size 245/40 R 20 275/35 R 20
Old Dec 9, 2024 | 06:21 PM
2018 S560
Oh I thought the size was 35. My bad. It would be pretty close though although probably not advisable with the awd setup.
Old Dec 9, 2024 | 09:02 PM
2018 S560
Is strange because tire rack does not even list the 285 40s. That’s why I made the assumption that it was the 35s. That’s one reason I didn’t go with the staggered option. Tough sometimes to find both sizes available. In my size the 255 s 20s they are 271 dollars each. Still not a bad deal. Although I’ll probably go with the Conti dws06 extreme contact tires when these where out at least I could drive the car in snow then if need be.
Old Dec 9, 2024 | 09:20 PM
W205C43PFL's Avatar
Wonder if they are trying to clear old stock? ie. it is manufactured last year? check the date code after DOT.
