E-Class (W214) 2024 -
Engine oil specification for W214 E53
Old Mar 31, 2025 | 02:40 PM
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by Hicksra
I believe the manual is set up based on the less information they give you, the greater the probability you’ll bring it in and pay them for service
I am almost there, but I am worried that the dealer will charge an extra $200 to remove and re-install the Strut Tower Brace to do the oil change.
Old Mar 31, 2025 | 02:43 PM
Steven H-R's Avatar
2025 E53 AMG
For me it's not a matter of cost, I simply have trust issues.
Old Mar 31, 2025 | 02:47 PM
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by L1Wolf
I'm wondering about the same thing. I've changed oil twice in the E450 and never got mote than about 8 liters out. I've always attributed that to the car being on an angle, but now I'm wondering if the manual is wrong.
When you replaced the oil did you just add the same amount that you drained out? My ramps are 9" high so I am considering changing the oil on my drive were it slopes downward so that the car remains reasonably level.
Old Mar 31, 2025 | 03:02 PM
LAZARU5's Avatar
2025 E53 Hybrid
Originally Posted by Steven H-R
If it even actually applied to our vehicles... Print and online versions aren't even the E53, but the in-car electronic version would definitely fit your description, with vagueness abounding.
Is the AMG Supplemental booklet that was included with your owner's manual the Spanish edition? If it is the English edition, could you post the part number printed on the back cover?
Old Mar 31, 2025 | 03:19 PM
LAZARU5's Avatar
2025 E53 Hybrid
Trust is definitely a concern. Once I have an authoritative document that specifies the oil viscosity, quality spec, and capacity for the W214 E53 I would like to ask the MB service department which oil and quantity they would use to see if it is in agreement with the document.
Old Mar 31, 2025 | 03:54 PM
Steven H-R's Avatar
2025 E53 AMG
Picked my car up from the dealership March 7th, it’s the Spanish edition.
Old Mar 31, 2025 | 04:29 PM
  #32
W205C43PFL's Avatar
Valid concern for sure unless you actually do analysis and stuff you never know if the dealership actually changed the oil.
Old Mar 31, 2025 | 06:46 PM
  #33
L1Wolf's Avatar
Veteran: Army
W214 E450
I measured the amount of oil removed and put in the same amount of fresh oil.
Old Apr 11, 2025 | 07:29 PM
  #34
Steven H-R's Avatar
2025 E53 AMG
Had an alignment done today at the dealership, took this pic while picking up a filter and plug from the parts counter.
Old Apr 11, 2025 | 07:37 PM
  #35
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbw...bdbcb121a.jpeg
I wonder why the transfer case doesn't have a mb approval specification displayed.
Old Apr 11, 2025 | 07:59 PM
  #36
Steven H-R's Avatar
2025 E53 AMG
Worth noting, they are using Mobil1 Euro at spec 229.5 in their oil changes for this application....
Old Apr 11, 2025 | 08:01 PM
  #37
LAZARU5's Avatar
2025 E53 Hybrid
Is that screen shot the results after entering the VIN from your E53? If so, this seems like a definitive description of the capacity, quality, and viscosity for the E53 oil.
Old Apr 11, 2025 | 08:22 PM
  #38
Steven H-R's Avatar
2025 E53 AMG
Yes, you can see the vin in the url.
Old Apr 11, 2025 | 08:44 PM
  #39
LAZARU5's Avatar
2025 E53 Hybrid
Seems like a good reason to do our own oil change.
Old Apr 12, 2025 | 02:45 AM
  #40
cruise2024's Avatar
S-class, E450 W214, E350 W214
So the dealership actually used 0W40 grade oil rather than 0W20 that is specified in the recommended spec sheet.
Old Apr 12, 2025 | 04:06 AM
  #41
Steven H-R's Avatar
2025 E53 AMG
0w20 is not specified for the E53, 0w40 or 5w40 per the in-car electronic manual, 0w40 specifically called out in the screenshot I took.
Old Apr 12, 2025 | 07:24 AM
  #42
LAZARU5's Avatar
2025 E53 Hybrid
Did someone at the dealership volunteer this information about using 229.5 instead of 229.51/229.52?
Old Apr 12, 2025 | 08:15 AM
  #43
Steven H-R's Avatar
2025 E53 AMG
I simply asked for the oil they were using, he brought out the Mobil1 Euro. Seems the dealership is having just as hard of a time sourcing the correct spec 0w40 as we are.
Old Apr 12, 2025 | 08:31 AM
  #44
W205C43PFL's Avatar
Dealerships like to stock certain oils that works for both gasoline and diesel. That saves on costs. Is this oil the one that works on their BlueTEC vehicles as well? I can't remember.
Old Apr 12, 2025 | 09:33 AM
  #45
Steven H-R's Avatar
2025 E53 AMG
I think thats the rub. The spec for Bluetec is the same 229.51/52 but the viscosity is wrong. They did tell me they don't have the oil for the E53 in the bay pump heads, so they hand out bottles to the techs.
Old Apr 12, 2025 | 10:11 AM
  #46
LAZARU5's Avatar
2025 E53 Hybrid
I wonder if MB issued a service bulletin allowing the dealers to use 229.5 0w40 spec oil if 229.51/229.52 is not available. I will be making the first oil change in a couple of months and I am probably going to order Mobil 1 ESP X4 0W40 unless the Liqui Moly 4120 becomes available. Like @L1Wolf I will be checking the engine oil level on the dashboard before starting and measuring the amount of oil that is drained to see how close it comes to 7.3 liters.
Old Apr 12, 2025 | 10:24 AM
  #47
Steven H-R's Avatar
2025 E53 AMG
4120 is my desire for sure, though without a true directive from MB, I too will be using ESP for my first change next week. Don’t want to be caught out with an issue and receipts for the wrong oil.
Old Apr 12, 2025 | 11:01 AM
  #48
W205C43PFL's Avatar
Ya in that case really recommend just buying other brands like liqui moly, pennzoil, motul, amsoil etc.
Old Apr 12, 2025 | 11:23 PM
  #49
LAZARU5's Avatar
2025 E53 Hybrid
Can anyone explain the difference between the oil specification and capacity in the screen shot in post #34 and this excerpt from the Jan 2025 online E-Class manual? MB is really doing everything they can to get customers to inadvertently change oil with the wrong spec and capacity. Whoever is responsible for editing the owner's manual deserves to be fired. I don't believe 229.71/72 oil is even available with 0w40 viscosity.
https://www.mbusa.com/en/owners/manu...s-amg-vehicles
Excerpt from January 2025 online E-Class Owners Manual
Excerpt from January 2025 online E-Class Owner's Manual
Old Apr 12, 2025 | 11:49 PM
  #50
Steven H-R's Avatar
2025 E53 AMG
Honestly looks like poorly edited combined info from other parts of that same manual. In the non AMG section it calls out .71/.72 and the same lower capacity for “All other models”.
The picture I posted was live data from xentry.
