New Wheels
I was referring to the E450 All-Terrain Wagon's AMG wheels, when I posted the prior post.
Either way, the following are the specs between the 2 cars:
E53 AMG (wheel-size / Offset / Tire-size):
20x9.5 front / Offset: 25.2 / 265/40/20
20x10.5 rear / Offset: 43 / 295/35/20
E450 All-Terrain 20" (wheel-size / Offset / Tire-size):
20x9 front / Offset: 32 / 255/40/20
20x10 rear / Offset: 48.1 / 285/35/20
The E53 wheels will move outward by 6.8mm in the front, and 5.1mm in the rear, based on the offset (virtually invisible).
The tires seem to be a tiny bit taller in the E53, vis-a-vis the E450 All-Terrain, since both have the same aspect ratio, while the E53 being 10mm wider front/rear.
Still not decided.
The tires are Mercedes OEM-Spec Pirelli Max-Performance Summer tires, and once the season is over, I plan to replace this set, with either of the below combinations:
255/40/20 Front (overall height 28"), 295/35/20 Rear (overall height 28.1"). ====> Combination 1
265/40/20 Front (overall height 28.5"), 305/35/20 Rear (overall height 28.4") ====> Combination 2
The 2nd combination above, is a wee bit taller than Combination-1, but overall, should work with no fitment or other issues. The wheels are wide enough (specifically for combination-2), based on my checking.
https://cimg4.ibsrv.net/gimg/www.mbw...d7ea2a275e.jpg
https://cimg8.ibsrv.net/gimg/www.mbw...69e303f412.jpg
I currently use a spray on wheel cleaner, a Speedmaster Wheel Brush, and I coated them with Carpro CQuartz DLux. They still don't clean up as easily as I would like them to. And, I honestly don't know if applying the Carpro DLux actually did anything.
