E-Class (W214) 2024 -
E/W214: Temp/climate control switches on evry time car starts
Old Apr 18, 2025 | 05:36 AM
Lochetive's Avatar
E3ooe W214
Hello Folks,
W214 E300e - every time I get into the car and turn it on the climate control (fan and temp) on - even though I've turned it off when I left. As for the Sync - god alone knows . it seems to have a mind of it's own regarding front and back Ive just given up on that.
The radio used to turn itself on every time too but at least that's stopped. If I know how dependant everything is in the car on the central screen thingmy I would never have purchased - give me tacticity with buttons any day. All help much appreciated re the climate control turning itself on automatically - how do I stop that?. Plus only get about 30 miles if I'm lucky on the battery.
Old Apr 18, 2025 | 08:17 AM
W205C43PFL's Avatar
Originally Posted by Lochetive
Hello Folks,
Sounds like a profile sync issue?
Old Apr 18, 2025 | 09:13 AM
Lochetive's Avatar
E3ooe W214
sorry - a what?
Old Apr 18, 2025 | 10:32 AM
W205C43PFL's Avatar
sorry - a what?
Profile syncing, when you start the vehicle, it will prompt you to select your profile. It defaults to guest until you select one and authentic with a PIN or biometrics.
Old Apr 18, 2025 | 12:58 PM
regor60's Avatar
06 E55 Black
Mine defaults to my name...🤷
Old Apr 18, 2025 | 01:45 PM
W205C43PFL's Avatar
Do you then authenticate? You might have access protection turned off.
Old Apr 18, 2025 | 02:46 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Are you remote starting the vehicle?
Old Apr 18, 2025 | 03:52 PM
oncsy's Avatar
W206 C43 ; W214 E53
Mine is doing the same. It is standard, and the same happens with the infotainment (music). If I set the air blowers to a specific possition when I restart the car the move back the central possiton. It also forget the DigiVent setups at every startups.
It is very annoying, you cannot do anything with that.
Old Apr 19, 2025 | 08:57 AM
W205C43PFL's Avatar
Sorry to hear that.
Old May 6, 2025 | 02:26 AM
Lochetive's Avatar
E3ooe W214
no. Just when I get in and press the start button it’s an absolute pain. The seat sometimes move of. It’s own accord and sometimes the heating/air
con just doesn’t work. Why in earth would you not want the radio and climate control the same as when you left it - so the car thinks it knows better than the driver and turns things on? The dealer said that that’s meant I happen - eh-why? The glitches and things like this and the complete over automisatuon and also the annoying screen that you have to use with the lack of tactile buttons mean I will never buy another merc. Too clever by half. Oh and also the local dealer is just awful. Never again and I’ve been brand loyal for 15 years. Time for a change. Sorry for the rant but I found that rather cathartic!
Old May 6, 2025 | 05:01 AM
Michael Safley's Avatar
2021 CLA 2.0 AMG W118
Hello Folks,
On many newer Mercs, the climate control is designed to default on every time you start the car, as part of the automatic comfort settings.
Go into the AC menu on the MBUX screen, then check if “Auto” is enabled.
Disable both “Auto” and the “Pre-entry climate control” option in the vehicle settings under ‘Comfort’ > ‘Climate Control’.
Old May 6, 2025 | 08:04 AM
W205C43PFL's Avatar
Wait so this is standard behaviour on the W214? It wouldn't make sense as if you turn it off it should indeed be off like other MBs.
Even remote start won't turn it on unless it was set to auto from experience but again my experience doesn't include a W214.
Old May 6, 2025 | 08:05 AM
W205C43PFL's Avatar
Thanks for chiming in, how newer is newer?
Old May 6, 2025 | 11:24 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I just tried in my 2025 E450 today and found the climate control remains off when starting if its off when I shut the car down previously.
Old May 7, 2025 | 02:56 AM
W205C43PFL's Avatar
That is expected behaviour so really not sure what happened to OP's car. Unless there is a setting that was missed.
Old May 7, 2025 | 03:01 PM
tode's Avatar
W214 E300e
Hello Folks,
I have the same car as you (E300e) and I've had none of these problems. Maybe you should plan to spend a few evenings with the manual . . .
Old May 7, 2025 | 05:19 PM
W205C43PFL's Avatar
Or maybe there is an actual software issue with OP's car you never know I guess.
Old May 22, 2025 | 02:21 AM
Lochetive's Avatar
E3ooe W214
Hello folks. Thanks for all the suggestions and comments. I have tried all the suggestions - everything so far and it still does it. I have even taken it in to the (useless) dealer here in Scotland. I see that one of the other posters in this has the same issue. The dealer even said that this is the norm - so I don’t know if I’m just being fed a line by them - my point to them is - why in earth would I want the radio and climate control turned in every time I got into the car when I turned it off when I got out.
anyway if any more comments on how this
might be fixed that would be fantastic! It’s driving me
nuts!
Old May 22, 2025 | 10:05 AM
W205C43PFL's Avatar
nuts!
I wonder if it is region specific, certain regions have it on for whatever reason, it seems the folks in the usa don't have this problem.
Old Jun 5, 2025 | 08:05 AM
TulsaVic's Avatar
2025 S580
My climate settings stay where I left them. But my radio volume doesn't, not only volume level but mute also. At least the stations stay. And every once in awhile I can see the turn signal indicators so I know my seat/steering wheel settings have mysteriously changed, requiring hitting the memory button. 2024 E450 AT.
