E-Class (W214) 2024 -
E450 Wagon Noise from Tailgate
Old May 5, 2025 | 09:17 PM
CajunMB's Avatar
Just bought a new E450 All Terrain. As we drive there is noise from the rear - sounds like the tailgate - that sounds like the rear wiper is actuating but the wiper isn't moving. It's unclear what it is. Happens intermittently but regularly. Thoughts?
Old May 5, 2025 | 09:35 PM
W205C43PFL's Avatar
Likely backup camera.
Old May 5, 2025 | 09:36 PM
W205C43PFL's Avatar
https://mbworld.org/forums/gle-class...very-stop.html
Old May 5, 2025 | 09:37 PM
W205C43PFL's Avatar
Long story short, it is a "buggy" calibration process, introduced on recent MB models.
Old May 6, 2025 | 01:49 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
I haven't noticed this in my 2025 E450, but I often have music playing loud enough to not hear the camera popping in and out. I'll listen for it, but I would have thought I would have noticed this at some point over the last 12 months.
Old May 6, 2025 | 07:48 AM
W205C43PFL's Avatar
Do you think OP's issue is this backup camera or do you think it is some other hinge mechanism or some other mechanism?
Old May 6, 2025 | 08:17 AM
mykel79's Avatar
GLE
If it is the camera, then try to notice:
- Does it happen every time you stop?
- Is it the same sound as the camera opening when you go into reverse?
Those two things would be the first to confirm or rule out.
Old May 6, 2025 | 08:19 AM
W205C43PFL's Avatar
Another method is opening it manually, there is a setting to open rear cam (I guess for cleaning).
Old May 6, 2025 | 08:21 AM
W205C43PFL's Avatar
https://www.mercedes-benz.ca/en/owne...e-camera-cover
Old May 7, 2025 | 05:12 AM
stymiedny1's Avatar
W214
I get the same on mine and happens when you brake. I forgot to mention this when I had it at the dealer but the loaner they gave me was the same car and it made the same noises. You described it right. It sounds like a motor similar to the wiper motor
Old May 7, 2025 | 04:50 PM
W205C43PFL's Avatar
Yup backup camera. Thing is it pops up to calibrate despite not showing an image on the screen.
Old May 7, 2025 | 06:23 PM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
I wonder if it comes down when you stop to monitor cars approaching you from behind for safety reasons.
Old May 8, 2025 | 11:03 PM
Roweraay's Avatar
X214
I am still at a loss to understand what the camera is trying to “calibrate”, multiple times during a short trip !
Old May 9, 2025 | 02:31 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
I doubt its calibrating. It's more likely that it is using the camera for some of the driver assist functions and needs to pop out in those circumstances. Then, it goes back in when its not needed to avoid getting dirty.
Old May 9, 2025 | 10:31 AM
W205C43PFL's Avatar
Me neither.
Old May 9, 2025 | 10:32 AM
W205C43PFL's Avatar
I would agree and I think you have a good point but it doesn't do this on older model MBs and certain forum members' newer model MBs prior to a certain MBUX update. So not sure what is up with that, we can argue older model MBs don't have as many safety assist systems, sensors etc. but these older model MBs are not even that old. Actually, some are pre-facelift of the same generation or just one or two model year older.
Old May 9, 2025 | 11:20 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
There are plenty of differences between the cars, especially older ones that would explain why this happens more on newer cars. It may not even be a difference in features, but rather a difference in how some are implemented. The newer models do a lot more with cameras in combination with radar sensors to detect other objects. It's a combination of software and hardware that dictate how a feature is implemented and the newer cars typically have more advanced hardware. It may not even be a different camera. It could be that other newer sensors can use camera inputs in ways not possible on cars made a few years ago. It's hard to say without an explanation from MB.
Old May 9, 2025 | 11:51 AM
W205C43PFL's Avatar
I see, then putting that aside, what are your thoughts on some having the exact same model year yet one does it, the other doesn't. The differences were just one software update (this was reported in the GLE thread). I would think it has to do with options but they also denied that. Any ideas? I am curious why it happens as well.
Old May 9, 2025 | 07:05 PM
Roweraay's Avatar
X214
In case of the GLE, till the 2023 model, it did not do it. From the 2024 refresh, it started doing it.
Old May 9, 2025 | 07:10 PM
W205C43PFL's Avatar
On the other thread, a forum member that has a 2024 didn't do this, so that is what makes it stranger. As far as what I learned, most 2024 model year vehicles all do this, all the way down to A Class and SUVs like GLA and GLB.
Old May 9, 2025 | 07:24 PM
Roweraay's Avatar
X214
Unless it was a 2024 model that was really early in the production cycle, and somehow had the 2023 camera hardware/software added onto it, I doubt that would be the case. Maybe the forum member is not very tuned into the noise the camera makes, as it continuously deploys and goes back in.
Old May 9, 2025 | 07:44 PM
W205C43PFL's Avatar
I see, possible. Anyways, here is the forum member I was talking about and their post: https://mbworld.org/forums/gle-class...ml#post9152957
Old May 9, 2025 | 07:45 PM
W205C43PFL's Avatar
https://mbworld.org/forums/gle-class-v167/876324-rear-camera-pops-out-every-stop-7.html#post9124214
https://mbworld.org/forums/gle-class-v167/876324-rear-camera-pops-out-every-stop-3.html#post9092929
Old May 9, 2025 | 07:46 PM
W205C43PFL's Avatar
https://mbworld.org/forums/gle-class...ml#post9089219
Old May 9, 2025 | 08:46 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Lots of speculation and too many what if's to draw any confident conclusions. Some may not hear the noise even though it pops out. Others may be missing an option or have some feature disabled that results in the missing behavior. I don't see it as an issue and therefore not concerned myself. The car makes other noises that appear normal to the operations of the car. Nothing unusual about the camera popping out while driving.
