E-Class (W214) 2024 -
Engine Oil Level
Old Jun 1, 2025 | 03:20 PM
leadfoot4's Avatar
2024 GLE 450; 2024 E450
Engine Oil Level
Call me stupid, but I can't seem to be able to figure out how to check the engine oil level, on my 2024 E450. I'm aware that there isn't a traditional dipstick, but I've scrolled through the various icons on the dashboard's information screen, but can't find one that displays the engine's oil level. And for that matter, I can't find one that displays tire pressures, either. And with respect to the tire pressure, one time I summoned "Hey Mercedes", and asked to display the tire pressure, and the reply was "you aren't a subscriber to that service", or something like that.
Can any of you folks help out a "newbie"??
TIA.......
Old Jun 1, 2025 | 04:14 PM
Hicksra's Avatar
GL450, E450, Porsche 718 GTS
You can easily see tire pressures on the Mercedes Me app.
Old Jun 1, 2025 | 04:44 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
Hit the home button on the left side of your steering wheel. Then use the arrow pad to scroll all the way to the rightmost driver display mode called Information. Then hit the OK button. This is all on the wheel and on the driver display, not the central display. The information screen shows tire pressure, tire temp, and oil level.
Old Jun 1, 2025 | 05:14 PM
leadfoot4's Avatar
Thanks for the info! I assume that this is done with the ignition "on", but the engine off, correct? (at least for the oil check, I mean.....)
Old Jun 1, 2025 | 08:37 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
You can switch to that display with the engine off and ignition in ACC, but you will not get any tire or oil info until you start the engine. Tire pressure requires you to drive a few 1000 feet before they register any info as well.
Old Jun 2, 2025 | 06:50 AM
leadfoot4's Avatar
Coming to M-B, from the world of Jaguars, and other, older cars that had dipsticks, I find it interesting that the oil level is checked with the engine running. On our last Jaguar(s), with the electronic oil level sensors, the level was checked with the engine off, as it was also done that way with our previous cars that had a dipstick.
It also appears that I need to log onto the "Mercedes and Me" application........
Old Jun 2, 2025 | 09:09 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
It is a bit different and I wish it still had a dip stick. I think it's all part of MB trying to keep owners from servicing their own cars. The computer measures the oil in the pan and compensates for what is circulating through the engine.
You do not need to login to Mercedes Me to check the oil if that what you meant. Mercedes Me is only needed for the digital extras such as remote start. Another item they should have just put on the key fob. The first year of digital extras are included in the price of the car. Then they become an annual renewal cost.
Old Jun 2, 2025 | 09:15 AM
regor60's Avatar
06 E55 Black
Did you not read the answer provided ?
There is no need to log into any app to check oil level or tire pressure.
Old Jun 2, 2025 | 04:18 PM
W205C43PFL's Avatar
For the most precise measurement (down to the amount in liters) you need to check it in the workshop menu, the bar doesn't show numbers, ignore the part where the video scrolled to the ASSYST PLUS menu, you need to go to vehicle data instead, keep in mind the workshop menu auto hide itself next time so you need to do this everytime :
Old Jun 2, 2025 | 05:16 PM
leadfoot4's Avatar
YES, I did read the answer(s) provided, HOWEVER, I did not immediately go out to the garage and attempt to pull up the "service screen" on the dashboard display. I did that this morning, and was able to find both the oil level. as well as the tire pressures displayed.
Old Jun 19, 2025 | 09:16 PM
liexpress's Avatar
2024 E450
Yes, you don't know if the engine can run safely with current engine oil level until the engine runs. Totally doesn't make sense.
Old Jun 20, 2025 | 11:09 PM
W205C43PFL's Avatar
Exactly.
Old Jun 21, 2025 | 12:02 PM
LAZARU5's Avatar
2025 E53 Hybrid
When you check the oil in the Workshop menu you are will see a question asking if the engine is filled with oil.
Workshop screen in E53 Hybrid.
Old Jun 26, 2025 | 01:17 AM
W205C43PFL's Avatar
So that begs the question... is it?
Old Jun 26, 2025 | 10:30 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
The assumption is that bringing up the menu is during the engine oil service. Therefore, the question is a reminder in Germ-lish. Along the lines of ... " Did you remember to fill the engine with oil? " to give pause before starting an engine that might not have had the oil re-flled, added, replaced, poured in or filled in, most importantly because the menu is available after engine start.
