E-Class (W214) 2024 -
Steering wheel capacitive buttons solution
Old Sep 1, 2025 | 04:38 AM
nanis123's Avatar
E200 2025
I’ve discovered that using my fingertips to operate the steering wheel’s capacitive buttons, rather than the softer, larger part of my fingers, yields better results and fewer errors. What has been your experience with this approach?
Old Sep 1, 2025 | 09:05 AM
W205C43PFL's Avatar
Seems like a good method to try. Some use their nails I am not sure how does that work.
Old Sep 1, 2025 | 07:57 PM
TulsaVic's Avatar
2025 S580
My problem was never having trouble activating a function. It was getting my hand or finger too close to the controls and activating something I didn't want activated. I was forever loosing the center map image or having the audio turn on or off or have the volume change. Fixed that by trading in the wagon and leasing an S-class. Same steering wheel but for some reason no problem with the controls.
Old Sep 1, 2025 | 08:52 PM
W205C43PFL's Avatar
Software sensitivity, calibration issue?
Old Sep 1, 2025 | 08:58 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
It may be since I don't have any of those issues. Even on two different W214s.
Old Sep 1, 2025 | 09:27 PM
W205C43PFL's Avatar
I wish we can adjust it..
Old Sep 2, 2025 | 02:39 PM
beechcamp's Avatar
2025 E450 All Terrain Wagon, Nautical Blue Metallic, Macchiato Beige/Black Interior
Yay! Adjustments can be made which may help them to work better for some folks. See highlighted text from the owner's manual, below.
Old Sep 2, 2025 | 03:10 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
I've seen that setting and always thought was for the touchscreen, not the capacitive buttons. Who knows though. I've never changed the settings for this so I'm not really sure.
Old Sep 2, 2025 | 04:26 PM
beechcamp's Avatar
The "SETTING THE SENSITIVITY FOR TOUCH CONTOL" is in the section of the manual that speaks to the steering wheel touch controls and it is after this section that the manual refers to touch screen operation. I only clipped the sensitivity part on my earlier post.
Old Sep 2, 2025 | 09:17 PM
W205C43PFL's Avatar
Awesome!!!! Thanks both, this will be a game changer!
Old Oct 1, 2025 | 07:18 PM
alanluddite's Avatar
2026 E 450, 2021 Dodge Challenger SPWBS, 1987 Buick Grand National
I only took delivery six days ago. As far as those wheel controls I’m still at the “Why, just why?” stage. BTW is it possible to open the roof just a little without opening the shade completely? I like to park on hot days with my roof tilted up and shade just open a couple of inches. Actually this shade can be closed since it breathes. Possible?
Old Oct 1, 2025 | 09:11 PM
W205C43PFL's Avatar
Yes, use ventilation mode. It will open a bit of the shade and the rear of the roof will leave a gap.
Old Oct 2, 2025 | 09:45 AM
TulsaVic's Avatar
2025 S580
Learned a trick for returning the driver's screen to where you set it when you accidentally change the view by touching the "select" pad (the one with the 4 arrows): Once you pick the desired instrument display and what you want in the centered display, press the "select" pad twice. That essentially memorizes the settings. Then if you accidentally change the view, or want to temporarily change the views, you just have to tap the "return" pad to get back all the original preferences. I was constantly brushing the "select" pad when making turns which resent the center display and had to scroll through the selections to get back what I wanted (the mini map display). This works for returning both the center display as well as the instrumentation.
Old Oct 2, 2025 | 01:52 PM
Thanks. The closest thing I found to that is Convenience Opening on p.103 of my manual. Not what I can use while left parked. Doors unlocked and seat ventilation running. I don’t want to take this Steering Wheel thread OT. It looks like I’ll just have to leave the door windows cracked a little as if I didn’t have sunroof. Tilting up while leaving the shade fully open and all that sun coming in defeats the purpose. I could have the roof ceramic tinted but I’ve spent enough. Thanks for the suggestion.
Old Oct 2, 2025 | 10:43 PM
W205C43PFL's Avatar
Sorry that I wasn't able to help. You can still use that summer convenience feature but let go instead going through the full sequence to achieve the same thing. Point key at driver's door at the indent (sensor) hold unlock until windows respond, let go at your desired position.
Old Oct 3, 2025 | 12:05 AM
W205C43PFL's Avatar
Just remember to lock vehicle afterwards
Old Oct 3, 2025 | 12:26 AM
Thanks I’ll give that a try.
Old Oct 3, 2025 | 12:29 AM
W205C43PFL's Avatar
My pleasure to help, basically the procedure is you lock the vehicle when you exit then you hold the unlock until the desired position you want then just press lock on the keyfob once without holding when you are done. You may also just do the keyless lock like you normally would once if you prefer.
Edit: Some vehicles (I guess all keyless go equipped MB vehicles in Europe) allow you to run the summer convenience procedure using keyless go by slightly pulling the handle, I believe that is disabled in North America. That said, you might be able to close the windows of the vehicle by tapping and holding it there and wait for vehicle to respond like you were to lock it. Just not unlock and put down the windows. I understand the W214 has pop out handles but it might behave the same as other MBs.
Old Oct 3, 2025 | 12:36 AM
W205C43PFL's Avatar
Here is what I mean, does not apply to the W214, I don't know if it was ever available on North American MBs due to regulations despite being on the ordering guide, just how newer MBs don't automatically close the sunroof when the rain sensor detects rain while European ones do (or can be enabled) Please kindly see page 9 https://mbworld.org/forums/attachmen...918d1500297621
