E55 AMG W211 Vendor Classifieds Forum Specific Vendor classifieds - Test sub-forum
Belt Wrap Kit for Supercharged M113 motors
Old Aug 21, 2012 | 09:46 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Originally Posted by GunMoto
What tune is recommended with this setup including the smaller S/C pulley w/stock crank pulley (assuming it's required)?
PM sent
Old Aug 21, 2012 | 11:53 AM
GunMoto's Avatar
EG8 | E46 | W211
Originally Posted by Bramage
If you go smaller top pulley a tune would be required **(highly recommended)
The choice of tune is entirely up to you. All the major players have tuned this modification.
Understood. Any local tuners in SD (or, OC)?
Originally Posted by shardul
PM sent
Thanks shardul!
Old Aug 24, 2012 | 05:06 PM
pearlpower's Avatar
E55 w/ goods, Z32 Project underway
Waiting for long term reviews; early adopters, please chime in with mileage and thoughts.
Old Aug 24, 2012 | 05:16 PM
Bramage's Avatar
F-250
Seems like a lot of New Fangled Halabaloo
Old Aug 25, 2012 | 01:44 PM
pearlpower's Avatar
Buyer silence on a new mod is never a good thing. Generally people post up impressions of a new buy while still in the box. I'm interested in this, but only when proven to not carry any baggage.
Old Aug 25, 2012 | 08:14 PM
shardul's Avatar
PP I will email some of the buyers and ask them to post their impressions.
Old Aug 25, 2012 | 08:23 PM
  #32
Hulk's Avatar
A Merc
Someone that has one told me that it's helped him up top and that is where most of the slippage happens
Will be getting one soon and will post my findings as well
Old Aug 25, 2012 | 10:47 PM
  #33
jcjmw's Avatar
2005 E55 Wagon
There are positive reviews. All the reviews that I have read were positive and I plan on getting one myself.
Old Aug 26, 2012 | 06:32 PM
  #34
pearlpower's Avatar
Sweet, thanks
Good to hear, must be posted somewhere else?
Old Aug 27, 2012 | 05:54 PM
  #35
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Here are pictures of SW`s belt wrap kit on his SL55 he just built last week.
I put my belt wrap kit on last week and just put the motor back in yesterday. Also added the smaller super charger pulley. I love just looking at it!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 27, 2012 | 07:17 PM
  #36
RonnieRenaldi's Avatar
SL55 AMG & BMW F10
What's the brand/specs on the smaller sc pulley?
Old Aug 27, 2012 | 08:37 PM
  #37
shardul's Avatar
Pm sent
Old Sep 4, 2012 | 02:16 PM
  #38
PLATINUM SPONSOR
2003 CL55
Our Belt wrap kit on my car with belts on it. I had the green belt extra, so threw it on for a little color.
The 83mm SC pulley`s sell out before each run is completed but will have a few to ship out Friday.
__________________
www.ultimatepd.com
Old Sep 4, 2012 | 06:27 PM
  #39
Hulk's Avatar
A Merc
Looks nice!
Old Sep 4, 2012 | 10:10 PM
  #40
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
Long Term Review & 22hp
Originally Posted by scoto
I installed my new Belt Wrap Kit last night. The install was very simple & I only needed a few hand tools. The install time was about 40 minutes. The Belt Wrap Kit is heavy duty and will work great with our engines I am very happy with this high quality product. I did a little test run after the install & noticed rite away big improvements. My SC engages smoother and the acceleration is improved especially from 3200 rpm and higher. I noticed big improvements between 40mph and 130mph & then backed off the throttle.
I have had my belt wrap kit installed for 28 days and put over 1200 miles on my car. The belt wrap kit is preforming perfectly. I am running the 84mm SC pulley with a kleemann 168 crank pulley. Prior to the belt wrap kit I noticed allot of belt dust on the top of my thermostat housing from the SC belt slipping. After the install no belt dust is present .I am very happy with this high quality product. My SC engages smoother and the acceleration is improved. I have put this belt wrap kit to the test including a trip to the dyno an also the dragstrip. I had my car dyno tuned by Eurocharged before the belt warp kit and decided to see if I gained any power after my belt wrap kit install. I made sure that the test conditions were the same for both dyno days to get as accurate results as possible. I am very happy with the increase of 22hp. I am attaching my dyno results for review.
http://i256.photobucket.com/albums/h.../dyno1_001.jpg
http://i256.photobucket.com/albums/h.../dyno2_002.jpg
Old Sep 10, 2012 | 03:19 PM
  #41
PLATINUM SPONSOR
2003 CL55
Here is my belt wrap kit on my new motor. Just click on the pic to see a quick video.
__________________
www.ultimatepd.com
Old Sep 10, 2012 | 05:45 PM
  #42
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
The reason you made 22hp more is because they used STD correction instead of SAE. Not a good comparison. STD corrects to a lower temp and makes 5% more.
Old Sep 12, 2012 | 12:04 PM
  #43
PLATINUM SPONSOR
2003 CL55
Looks like he still used a correction factor on both dynos (1.03 and 1.04) , so the STD was maybe not defaulted to it STD correction factor of (60 deg, 29.92 and 0 hum) in the program. Even if it was ran on the STD correction only , based on his air density numbers posted, it would not be even close to 5% difference.
Bottom line, with belt slip you loose boost and a little boost can easilly be 20-30 hp loss. Nice to see peopel starting to post thier feedback and dynos to give us ideas. It is common knowledge, that all our belts slip and the reason we get so much belt wear and nasty black dust all over our crank, sc and idler pulleys.
Below is a quote from GM Hightech magazine that explains STD
"STD Correction
STD, or standard correction, represents one of the oldest correction factors used by the Society of Automotive Engineers (SAE). STD is also known as J607 and it uses standard conditions of 60-degrees F, 29.92inHg and 0-percent humidity. For you engine dyno enthusiasts, these factors should look familiar, as STD (J607) is one of the most popular correction factors available and used almost exclusively by NASCAR teams to compare results from chassis dyno testing to results from the engine dyno. STD is also one of the most stable correction factors, in that it has not been changed for many years and the ideal factors remain consistent."
This is as close as I could get to my BW kit installed. Need to try a side angle for the next picture.
__________________
www.ultimatepd.com
Old Sep 12, 2012 | 03:19 PM
  #44
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Old Sep 16, 2012 | 04:33 PM
  #45
PLATINUM SPONSOR
2003 CL55
We put a belt wrap kit , power SC Pulley and new idler kit on a out of town car yesterday and here are the pics. Check out the video of the idler pulley. 06 e55 with 60K, idler seemed ok, until the SC belt was removed and wow, this one was gone!
Check out the video of the stock idler below, before we installed the 3 kits for him.
http://s991.photobucket.com/albums/a...5-11-11-36.mp4
__________________
www.ultimatepd.com
Old Sep 16, 2012 | 06:07 PM
  #46
Hulk's Avatar
A Merc
that belt really does have alot of contact with the SC
Old Sep 16, 2012 | 08:25 PM
  #47
Shifter's Avatar
E55, SL63, ML550
Just noticed, the belt resting on the belt wrap pulley doesn't look like it fully sits on the pulley,kind of hanging off the edge, is that normal?
Old Sep 16, 2012 | 08:29 PM
  #48
shardul's Avatar
No it was put on fully after the picture was taken
Old Sep 20, 2012 | 06:01 AM
  #49
99lightning's Avatar
99 ford lightning
What folks forget is during the cars shift is where you can lose boost so having belt wrap from a idler will keep your boost up. You may not always see it in dyno results but at the track. Either way these cars need this.
Old Sep 23, 2012 | 01:09 PM
  #50
PLATINUM SPONSOR
2003 CL55
Lot more contact/wrap on the crank pulley as well (the drive pulley).
The picture in my post above, was before the car was started or belts aligned. This car made 518 RWHP with SC pulley, belt wrap, headers and tune only! That is impressive and clutch engagment was extremely smooth.
__________________
www.ultimatepd.com
You have already rated this thread Rating: Thread Rating: 14 votes, 4.71 average.
