Smaller Supercharger Pulleys for M113K
#83
PLATINUM SPONSOR
In stock now, just contact Shardul.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#85
This was the question i was referring too Shardul
#87
PLATINUM SPONSOR
Always better to make the same or more power with less boost, if possible.
__________________
www.ultimatepd.com
www.ultimatepd.com
#96
I've been running one of these since last year and have put around 10K hard miles on it. One of the best mods you can do to your car, also highly recommend the belt wrap kit and ASP pulleys while you're in there. I'm at 84K miles and still crushing challengers left and right with the old E55
