Tuner / Programmer for 2.5L???
No such monster for our cars. You're also not going to buy another ECU that is pre-tuned either- it doesn't work that way. You take your ECU out (5 minutes), send it off, and they send it back- pretty quick turn around. You may be lucky enough to live near one of the shops/vendors that offer the tune. In which case- you drive there and they do it while you wait.
Mercedes uses a Bosch engine management system as far as I know and I'm not aware of any off the shelf systems that can manipulate the parameters in our ECU's. Obviously there is something out there or the aftermarket companies wouldn't be able to either.
www.mwhouston.com
5704 Southwest Freeway
Houston, TX 77057
(832) 419-8084
