V8 Thermostat 170 Degree- Add 30HP + timing
Old Dec 19, 2012 | 11:48 AM
gregc's Avatar
CLK 55
I have a Thermostat that is machined to 170 Degrees. Stock is 195 if I am correct. It will fit any of the V8's from the 2000's. I was to place on my 02 CLK 55 but did not. I fite the 430 too.
It only takes two bolts on the engine top and you do not loose much coolent to install.
A way to add 30HP to you car:
- go to a repair shop that has a MB tool. They can set your ECU 91 Octane gas. This will up the timing several degrees. It cost me $60.00
- add this thermostat and the car will run cooler. When the engine runs cooler, the ECU will add some more timing and lean out the fuel just a little.
I have a pic if you want to see, all clean and a new part. The guy that once made and sold these may not do it any more. I never figured out how he machined or changed out the metal sensor inside the case.
$120.00 + ship.
Old Dec 19, 2012 | 05:25 PM
Capn's Avatar
03' CL600
Any pics?
Old Dec 20, 2012 | 12:14 PM
gregc's Avatar
CLK 55
see pic attached
see pic
Old Dec 20, 2012 | 03:47 PM
scoto's Avatar
2005 E55, 2007 ML63, 2008 SLK, 2015 GLK350, BMW Z3, Dodge Power Wagon, Electric Smart car
will this fit my 2005 E55? If yes then I will buy.
Old Dec 20, 2012 | 06:04 PM
Fabio D's Avatar
210 55
Goodprice for a cooler termostat, they can be perfect for someone with performance mods (like: ecu performance tune, smaller pulley for more boost in S/C engines, headers, cams, etc) but cooler termostat and 91oct set = 30HP?.. i will cut my b..ls if you got this numbers. Trust me, no way.
But is a good price for this application
Fabio Daniel
Old Dec 21, 2012 | 09:21 AM
gregc's Avatar
CLK 55
Thermo Update
This thermo will fit the 4.3 and 5.4 from 90's up through later 2000's per dealer. Mercedes is pretty good at parts re-use in some areas. If it does not fit, please just send back for refund.
On the 30HP thing, this was a note from Dealer at 'crank HP', not wheeel HP adder.
All the 4.3 and 5.4 CLKs have the factory ECU set to 87 Octane gas. A dealer or local shop with reader "forgot name of unit' can set ECU to 91 Octane, as well as have Fan turn to high any time AC is on. The change to 91 up's the timing and AF a lot per dealer and I do notice the diff. (I run 91-93 Octane anyway).
The Thermo is a completly diff set of AF anf timing tables within the ECU map. When the temp is between 195 (stock) to 160 (cold), the ECU has several timing and AF tables it selects from. The colder the engine, the more aggressive the timing.
I have tuned may hot-rods with Superchargers over the years. The MB has some of the best anti-knock sensor setups I have seen. Not that is means much to this thread. The point is that the MB ECU will dynamically adjust timing the AF if if feels knock at the min.
Old Dec 21, 2012 | 09:23 AM
gregc's Avatar
CLK 55
HP
One more note. The 30HP assumes a KN filter too.
Old Dec 25, 2012 | 05:47 PM
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
$80 shipped
Old Dec 28, 2012 | 11:02 AM
gregc's Avatar
CLK 55
Part Number of Thermo
Sorry so slow.
If any of you want this let me know. I paid $120. Not worth my time to ship for less. Shipping should be $10.
Paypay is best payment.
Part: A 112 2030275
Thanks, and
Happy New Year.
Old Jan 6, 2013 | 02:07 AM
Beast55's Avatar
W211 E55 AMG Kompressor
Hello,, is this T-Stat still available???
Old Jan 7, 2013 | 03:20 PM
blackieclk550's Avatar
CLK550
if this gets sold where did you buy the original part ? i wanna get it for my clk550
