M156 Thermal gasket, OEM Breather Pipe,(10) bolts
Lowers intake manifold temperature by 15-20 degrees due to the thermal barrier between the intake manifold and the heads.
Breather pipe should be replace at 40-50k and the intake manifold must be removed and bolts replaced to change the breather pipe.
Thermal Gasket set, breather pipe and bolt kit for MB M156
OEM breather pipe and OEM intake manifolds bolts
$240/shipped in the continental US.
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1124/m156_thermal_gasket_breather_bolt_kit_1__9573837c0c4122ef636a637c67f97ca49bfba784.jpg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1124/breather_pipe_and_bolts_1__12e22e0dd979366a3cea035de395822719df454c.jpg)
15-20 degrees cooler intake manifold=MORE POWER!
BUMP!
Breather pipe should be done at 40k-50k and intake manifold has to be removed to do it. Why not upgrade to thermal gaskets while you're at it?
$240/Best Offer shipped in the continental US!
