Blind spot, collision avoidance inoperative
It's also possible that your vehicle is parked in a structure that gives off a very weird radar signature, which makes it throw an error on startup. When you're parked elsewhere and start the car after having been parked for a while, does it still do it? If so, the dealer can re-normalize the radar system, takes just a few minutes and should solve any issues that might continue.
If tire pressure is normal, it could well be one of the RADAR modules. About 8-10 years ago, there was a rash of bad Continental Teves RADAR units. To make matters worse, the number needing to be replaced created a huge supply shortage, so it took weeks or even months to get replacements. I highly doubt there's a shortage today, but it's not impossible that one of the units is faulting. If it wakes up and throws an implausible reading code, it may need replacement. From my memory of how SDS logs this, it should be immediately apparent which module is generating the fault. Good news is, it's easy to replace and recalibrate, you should be up and running in no time. Please let us know how it goes!
Bingo!!! I reset the original profile and now the Welcome display is functioning (it was there but grayed out before). I had to reset all of the unique parameters for media, radio, lighting, etc.but I think that this cleared up my original issue as well. I
Re: remote diagnostics: Ironically, GLKs back in 2014 were supposed to have remote diagnostics. I don't think I ever got a call about a fault in that car. I'm not surprised EQE does this well though, there's so much that's sent in real time over the telematics. Thanks for confirming this!
MB dealers are not going to be like those independent shops where they will just put anyone on a new model car to forget a screw, clip, or scratch up a finish because of inexperience assembly/disassembly of parts. In my experience, dealers are trustworthy in that aspect to get the job done right IF they know what they need to replace. Your car will likely come back as if nothing has been removed. It also helps if the dealer has an inhouse collision center. All the experts in one place.
