MB Wallbox - free!
))Question - . Has anyone used both Chargepoint Flex and Wallbox? I assume a charger is a charger so there’s no real difference between the two since they similarly spec’d, but wanted to check.
Here is the link if you want to check. Not sure if it works outside the US. I was skeptical of it being some scam but i googled and it was legit. (And it worked for me).
https://link.bdainc.com/mbwallbox
Anyone put in their MB/EVBox units? Do you get more stats than what you see in the Mercedes Me Connect app without the Wallbox/EVBox? That's one thing that the Wallbox-made units have an advantage - fantastic stats reporting and aggregation of charger data.
Edit: And can you add more than one to your account?
Thanks again for the helpful tip!
Of course, that required running more cable, so I pulled some 6/2 cable to the breaker box in the basement, which is of course on the opposite side of the garage. Total time from tearing down the original Pulsar Plus units to pulling wires and installing the two new MB units was about 7 hours. And yes, there were about 6 trips to the hardware store because I'd invariably forgotten to get one small piece or another.
Now, I finally can charge both cars at max speeds without worrying about power sharing or crappy chargers with bad relays. There are several Ethernet ports inside, so you can connect via Ethernet, WiFi, or LTE (not available in the US, I suppose). Ironically, I do wonder if they did in fact support power sharing, as there are multple RJ45 jacks in there. But having full dedicated power has been great. The power relay on the MB units sounds just like the ChargePoint units - a powerful-sounding thunk and it's ready to go. Solid, and should last a long time. The integration into Mercedes Me Connect is pretty decent, and for those who are wondering, yes, you can add multiple MB Wallbox (made by EVBox) units to the same Mercedes Me Connect account.
Very glad I put these in!
