EQE (V295) Sedan Upcoming
Eqe 350 suv
Old Jan 16, 2024 | 09:38 PM
manvel17's Avatar
eqe
Eqe 350 suv
Hi for some reason my ability to change battery charge percentage stopped working. In the past I was able to change charge percentage from 100% to 80% or vice verse on the app. But now it won’t let me. I keep getting connection error. But I do have connection because I can activate pre climate. I can also lock and unlock the car from the app. I can also locate my car through the app. I’ve taken to dealer multiple times and they can’t figure it out. I also called Mercedes me connect over a week and still no call back to solution. Any help is appreciated
ted
Old Jan 16, 2024 | 10:20 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
Twice I ran into a situation where my car wouldn't update its status for about 2-5 hours. It happened in the same location, though I think that was coincidental. I called Mercedes Me Connect, and was escalated to Tier 2. As soon as Tier 2 called me back, it started working on its own, likely a network outage or similar issue. In your case, if you can actively send data to the car, but cannot adjust the charging threshold, it seems to me that it's an account or vehicle configuration issue. If a Tier 2 support specialist can't help you out, I'm not sure what to suggest. You could theoretically delete your user profile, which would also wipe out any charging settings, and see if creating a new profile solves your issue. If not, then it's account-related on MMC's back end, and only MMC tier 2 or above could approach a solution.
Old Jan 18, 2024 | 03:33 PM
BobZEQEC300's Avatar
C300EQE
I would change the charge threshold on the car up or down and see if that forces the app to do something. You can drag up and down the % on the mbux.
Old Jan 18, 2024 | 03:34 PM
manvel17's Avatar
eqe
thank you. I did try that as well. No luck. Just waiting on Mercedes me connect to get back to me and see if they can fix it
Old Jan 18, 2024 | 03:37 PM
C300EQE
Id also try stopping and starting the vehicle status service.
Old Jan 18, 2024 | 08:03 PM
HBerman's Avatar
2024 AMG EQE SUV , 2021 E63S Wagon - gone, 2018 E63S Sedan - gone
I'm broken also on my AMG EQE SUV. No status sin 12:33 PM today. However, I can lock the car via the app. Wierd.
Old Jan 18, 2024 | 08:23 PM
Have had issues with MMC today as well. I imagine it should be resolved soon.
Old Jan 18, 2024 | 08:26 PM
HBerman's Avatar
I just got off of the phone with the Me support line. The website is currently down (which also affects the Me app). There is no ETA for restoring the functionality. Bummer.
