EQE (V295) Sedan Upcoming
Panoramic sunroof shade noise
Old Jan 30, 2025 | 09:44 AM
teksurv's Avatar
2024 EQE 500
I'm now in my second EQE and in both (2023, 2024), when opening the sunroof shade for the pano roof, there is a loud clicking sound. This does not happen when closing the shade. It's the same sound on both of my EQE's. Has anyone else experienced this, or am I just unlucky twice? It sounds like the shade is binding in the track.
Old Jan 30, 2025 | 12:48 PM
bytemaster0's Avatar
2023 EQE350 4MATIC, 2023 EQE 350 4MATIC SUV, 2015 E250 BlueTEC 4MATIC, 1995 E300 Diesel
I haven't had this noise on either my sedan or SUV. I will say that on my sedan, I'll hear one slight slipping noise as the fabric, which was either under tension or rolled up, moves as it's being rolled open or closed. But no clicking like that on either car. Is it consistent, indicating it's tied to a gear, or is it a-periodic?
Old Jan 30, 2025 | 01:51 PM
teksurv's Avatar
2024 EQE 500
It's consistent, each time I open the shade, it clicks/binds in the same spot just for a moment. I'm taking the car to the dealer today for an unrelated issue, I'll mention it and see what they say.
Old Feb 3, 2025 | 07:22 AM
fm_carv's Avatar
GLE
I’ve had this problem with two clicking noises only when opening the shade. The sound was coming from the rear sunshade.
Mercedes tried to lube the mechanism but it ended with the rear sunshade being replaced under warranty.
Old Feb 3, 2025 | 07:30 AM
Yeah, I also have one click or so when it closes, it's either that the fabric has stretched or the roller is tensioning unevenly. I haven't worried about it much.
Old Feb 3, 2025 | 01:42 PM
fm_carv's Avatar
GLE
You should get it fixed. It’s a fault with the motor and will cost you when the warranty is out
Old Feb 3, 2025 | 01:52 PM
I don't think it's the motor. It's likely just the tension roller. It doesn't do this in warmer weather, so I assume it is related to the tension in the fabric as it cools.
Old Feb 3, 2025 | 09:00 PM
BobZEQEC300's Avatar
C300EQE
Mine clicks too but never really bothered me. I lease so 2nd owner's problem.
Old Feb 4, 2025 | 04:55 AM
fm_carv's Avatar
GLE
It’s the motor. I had mine at Mercedes in November to get the back sunshade replaced.
Can’t be fixed as it’s a complete unit. The roof liner needs to be removed to get this done. Thankfully it’s a separate part from the front sunshade.unit.
Now it works as it should with no noises.
Old Feb 4, 2025 | 03:03 PM
teksurv's Avatar
2024 EQE 500
Thanks for the feedback. I actually forgot to mention it as the car was in for something else (module software updates due to random errors on gauge cluster screen.) I will bring it up next time I am at the dealer, good to know it's not "normal."
