Electrify America’s CEO Takes a EV Trip…
Received 3,730 Likes
2019 C63CS
I can appreciate that they have to build a whole new infrastructure whereas gas stations have been around for decades, but at the same time it seams they are reinventing things to the point where problems are just bound to happen. I mean we've fueled at gas stations by swiping a credit card forever, but somehow that wasn't good enough so these charging providers developed mobile apps to do what a simply credit card swipe would have accomplished much easier w/o the need of a new server backend to handle the mobile app. Gas pumps run software, too, and many now have added mobile apps to the basic credit card swiping. For example I pretty much exclusively fuel with the Shell and Chevron apps. They've never failed. I never pulled up to a pump and had issues starting the process from the app. It just works. And even if it did fail, I can still swipe my credit card worst case. Why is it that the old school oil companies can make this work, but the fancy modern EV industry struggles with making their charging stations work reliably.
For gas, there is no electronic communication between the pump and the car. You press the handle and gas pumps out, regardless of whether the gas pump spout is in the correct position or not.
For electric charging, it is a bit more complicated, as they need to talk to each other to determine whether it was safe for charging to start and the charging speed.
2019 C63CS
The glitches and problems are usually related to the hand shake between the car and EVSE, and not related to the charges or credit cards.
Originally Posted by superswiss;[url=tel:8772813
8772813[/url]]I do understand that, but that isn't a factor if the charger is simply down when you pull up. Seems that is often the case that the charger itself just crashed or something. It doesn't even get to the handshake. The process is certainly complicated by the fact that there's a handshake, but it seems it often fails even before that. I mean just the fact that you can check the status of how many chargers are down at a particular site tells you that this is a common issue.
Sounds like a huge excuse from the technician. How exactly can a customer abuse the charger and why don’t Tesla chargers have the same problem?
The following 2 users liked this post by Utopia Texas:
23-EQS580-SUV (05-08-2023),
bpans (05-08-2023)
2019 C63CS
The cables on the Tesla chargers are not as difficult to manage. They are shorter, easier to plug into the car and hang into the charger holster. The Tesla connectors also do not have a latch which is susceptible to being damaged. Over the last five years I have used public L2 and L3 chargers well over a hundred times. The condition of J1772 connectors at destination chargers and the CCS connectors at EA is clearly much worse than the proprietary connectors at a Tesla Supercharger station.
2019 C63CS
I will say that the 350kW CCS cables are heavy and difficult to handle especially for women. This has been recognized in Europe and many of the providers there are now installing retractable cable holders with swinging arms to make it easier to handle them. The EU has also mandated that charging stations need to accept credit cards. It's again just kinda mindboggling that this wasn't thought of before, since nozzles at gas pumps have long had this. It's equally perplexing that most charging stations stand out in the open without a roof over them to protect the hardware and the customers from the weather.
I am very new but used EA for 3 or 4 times. What bothers me is the inconsistency. Last night, I plugged in my car in a station and the car was only drawing at 35 kW. I disconnected and moved to next station and I got 140 kW. They are just next to each other. The guy next to me using the 3rd station was seeing around 75 kW.
Another one that really bothers me is the location of the stations. A lot of time, I find it very hard to extend the plug to the socket unless you get to the correct side of the station and head out or back-in appropriately.
Originally Posted by Utopia Texas;[url=tel:8772968
8772968[/url]]Sounds like a huge excuse from the technician. How exactly can a customer abuse the charger and why don’t Tesla chargers have the same problem?
2019 C63CS
Exactly. Don't blame the customer if they are not designed to be handled easily by anyone regardless of physical strength. Often they are also too short and they don't bend well in order to plug them in.
2023 EQE 500 SUV electric and 2024 Jaguar F-PACE SVR 5.0L
I think EA has a good location strategy. I can almost go road tripping in my EQE just by hopping from one Walmart to another. Problem, as many others have point out, is their chargers just aren't reliable. There's one Walmart in Spring, TX with 150 kW chargers and when I went there today screen had a popup that said "reduced power because of a software update", yada, yada, and all of a sudden I'm at a 50 KW charger that's maxing out at 31kW. If I had been desperate for juice I would have been @#$%ed. So basically there are no 150 kw chargers within a 30 mile radius of my house right now and I'm living near a major metropolitan area. I can't imaging owning an EV near where this one was manufactured in Alabama. Better buy two and make sure the other does V2L (unlike my Mercedes) so you can rescue yourself.
Anywho, it was plug and play for me though. EA authenticated my car automagically and activity shows up in the Mercedes me app. There was no charge (pun intended).
The EA infrastructure in California has been good so far. I live in the San Francisco Bay Area, and have already taken road trips (with my EQS 580 SUV) to: Phoenix and back; St. George, Utah and back; Yosemite National Park and back; and San Diego and back. Occasionally I've found that a charger (usually a 350 kW charger) isn't working, but then the one next to it usually works OK. And only once have I had to wait in line for a charger space to come available: at Quartzite, Arizona (in the desert, near the CA-AZ state line) on a weekend. However, EV adoption in California is increasing rapidly, so it'll be interesting to see if EA's infrastructure can continue to grow to meet the increasing demand.
EQE 350+, EQS 450+, AMG C63
I think the broken abused handle excuse is BS.
I have three chargers that I use two down by my home and one up by my office. Each has four and the two down by my home are always broken and not broken like the handle but they say "power has been reduced so we can conduct maintenance" or it has a red X or the screen does not work. I have yet to experience a handshake issue between the car and the charger. I have reported the broken station using the app and after two months of reporting they are still down.
Their new Gen 4 chargers have integrated cable management that retracts automatically. So cable won't get kinked like winding it manually. Looks like they're addressing the issues:
