Are my expectations too high? (Ride quality, motor smoothness, quality control)
1. My steering wheel makes very subtle ticking/rubbing/clicking sounds when steering. It's pretty quiet, my front seat passengers can't hear it, but I can hear it from the drivers seat and I can ever so slightly feel it. It's starting to drive me a little crazy. Does anyone else have this issue? I'm hoping it's not normal and that it gets worse so it encourages me to drive 2 hours to my nearest MB dealer.
2. Front motor vibrations... I can feel every time my front motor engages/disengages because when it's using the rear motor alone, it's smooth as you'd expect an EV to be. When I dip into the throttle and the front motor engages (as confirmed by the Info -> Energy menu), I can feel it vibrating. It does it every time. I can also feel it at lower speeds when it cruises around using the front motor alone, it also vibrates in this case. I can tell when it's using and when it's not using the front motor without having to check the Info -> Energy menu because I can feel it.
(Please note: I'm not here to discuss front motor disconnects, simply whether or not anyone else feels these vibrations. We have other EVs including Teslas and they are smooth as silk. You feel NOTHING from the motors, which is what I expected from my EQS SUV. It feels a little like an ICE car when the front motor is being used)
3. Ride quality... I'm finding myself a little disappointed with the ride quality. I feel a lot more of the road imperfections than I'd expect to. A lot more is translated into the cabin than I expected from a car like this. It's stiffer than I'd like. I want to waft along and feel next to nothing but this isn't the case I'm finding. Does anyone else find the ride stiffer than they expected? I expected the "electric S-Class SUV" to have a better ride.
I’m surprised you find the ride quality to not be soft enough, in my opinion that is one of the EQS’ (Sedan and SUV) strongpoints.
What he said. No issues with ours no rattles, ticks or strange noises. The ride is somewhat hard but we have the staggered wheels with run flats so its to be expected.
I got my EQS SUV 580 delivered in december 2023 (Belgium, EU-spec car).
I experience the same vibrations as described by you. Worse... through the dealer, we tested 2 other demo 4-matic cars, with the same result. It is indeed vibrations on the front motor.
Did your dealer fix this ? Is there a recall known ? My dealer considers it "normal", which I don't want to accept.
Many thanks for any reply !
We have a brand new 24 Grand Wagoneer we're using for a few months, it is over 6400 lbs and the ride is uber smooth, so the extra weight stuff is not the issue. So far as squeaks and rattles not being heard b/c there's no engine noise well there's some truth to it, but many vehicles have very little engine noise and there's little to no rattles at all. If we continue trying to rationalize poor quality MB nor any brand will never make it right.
Back to the '24 GW...for $120,000.00+ I was surprised to experience it lacks in structural rigidity found even in lesser vehicles as it is a bit of a flexible flyer over certain types of bumps...completely unacceptable.
The EQS is much more rigid, quieter, and drives better than the Wagoneer, which is to be expected.
-Never got this addressed. Still does it from time to time. I've gotten used to it and don't really notice this now. I figure with only 9 months or so left on my EQS lease, I'll just ride it out and get another one and hope the new one doesn't have this issue anymore.
-I do still feel like I feel vibrations from time to time in the 30-40 mph range when the car cruises using only the front motor. Again, never got this addressed for the same reason as above. It's not all the time, just every once in a while, but again, I'm hoping a new one won't have this issue. A newer model will have the front motor disconnect which mine doesn't have, so I'm hoping this will be different on a new one.
3. Ride quality...
-I've learned a lot about the suspension, drive modes, and regen modes.
I've learned that between Eco, Comfort, and Sport drive modes, Eco offers the most wafty + floaty S-Class like ride quality. Comfort stiffens up quite a bit compared to Eco. It reduces a lot of the float. In addition, I've learned that the regen modes also affect ride quality. Auto/No Regen seems to be the softest, followed by Standard, and then Strong regen being the stiffest ride quality.
When I first complained about the ride being too stiff, I had been driving in Comfort with Strong Regen which is one of the stiffer setups. Now I use Eco and Standard or Eco and Auto when I want the smoothest possible ride and I'm satisfied.
Overall I'm really happy with the EQS and look forward to leasing another one with all the improvements that are making their way into the 2024 and 2025 models.
3. Ride quality...
What improvements have you heard re the 24-25's?
- soft close doors becoming standard
- more range from a bigger and new battery
- all new brake system for improved pedal feel
- heat pump
- front motor disconnect
- Hyperscreen standard on all models
- power opening and closing charge port door
- 5G internet instead of 4G
- Automatic lane changes have been added
- 4-zone climate is now standard
- Power opening and closing DOORS are now available as an option
- A little bit more trim and interior lighting on the back of the front seats
In Eco mode, it was listed as in Comfort settings. So in theory, there should not be a difference between Eco and Comfort mode?
- heat pump
