Nominal thickness of EQS SUV rear brake pad - 8mm
Edit: My understanding is that the brake pads need to be at least 50% of the thickness of new pad to pass the CPO inspection for an MB ICE vehicle. I wonder if there is a different thickness threshold for MB EVs, since a 50% thickness on rear pads would not be far from tripping the brake pad warning.
The EQS front pads start out thicker than the rear pads, but I am fairly certain that the sensor will be tripped at ~3.5mm just like the rear. So 50% thickness on the front pads would be well above the minimum state inspection threshold for the front pads.
Parked in front of Boyertown Auto Body Works factory which closed in 1990. Now the Boyertown Auto Museum in Boyertown, PA.
EQS SUV rear brake pad:
- Overall thickness (including anti-squeal shim) of just under 15mm.
- Thickness of friction material just under 8mm.
- Thickness of steel backing place just over 6mm.
2006 SL55 rear brake pad:
- Overall thickness (including anti-squeal shim) of just over 15mm.
- Thickness of friction material about 10mm.
- Thickness of steel backing place about 4.5mm.
I suspect that keeping the overall thickness of the brake pads close to the same dimension of 15mm allows the calipers to be used on both EV and ICE vehicles.
EQS SUV:
New rear pad: 6.15mm backing plate, 7.9mm friction material. Changing pads when friction material is 6mm thick would be very wasteful since warning light does not come on until about 4mm.
SL55:
New rear pad: 4.5mm backing plate, 10mm friction material. Changing pads when friction material is 4.5mm thick makes sense since brake sensor is just about 0.5mm from being tripped.
EQS SUV:
SL55:
