EQS EQS (V297) sedan
What 14-50 and 20-30 Charging Cables Do You Carry?
Old Aug 30, 2022 | 04:43 PM
c4004matic's Avatar
17 E43; 21 GLS580
Originally Posted by stealth.pilot
BTW If anyone wants a 16A-40A 120V-240V portable charger, then the BMW Flexible Fast Charger will be available for purchase standalone on September 22nd. The list price is $680 so I expect it will likely be available online around $600. The Ford is just over $400 but has 30A peak.
Will keep that in mind. In fact, any plugable charger like the home flex is "portable" however once a charger is 50 amp capable the cable requirements nixes any real notion of "portability".
Old Aug 30, 2022 | 04:56 PM
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
Agree. I bought 2 ChargePoint home flex chargers because I didn’t want to lug them back and forth from Florida and RI. Plus I got them at a $500 discount each so it made the decision easy for me.
Old Aug 30, 2022 | 05:21 PM
c4004matic's Avatar
17 E43; 21 GLS580
Old Aug 30, 2022 | 06:32 PM
stealth.pilot's Avatar
2022 Mercedes EQS 580
It's not terrible, but your point is well taken.
Old Dec 15, 2022 | 09:28 PM
Radman991's Avatar
I realize this is an older text but I recently purchased a TeslaTap mini 80 for my one week old EQS. I mistakenly shipped the tap to my Florida home (I’m in RI now) so I haven’t been able to test it. I read somewhere where people were complaining about the tap getting stuck and recommended lube. Have you had a chance to test it and any problems? Just where is supposed to get stuck? Tap to car, or Tesla cord to tap. Thx.
Old Dec 15, 2022 | 10:32 PM
c4004matic's Avatar
17 E43; 21 GLS580
Ive only used mine once. No problems. If you wish to lubricate it use lithium grease. Its non conductive and light duty. You can also spray it with WD 40 that has lithium grease. Probably the simplest way.
Old Dec 15, 2022 | 10:56 PM
  #32
Radman991's Avatar
I have dielectric grease. I think that may work. I know you said you had no problem but what end do you lubricate.
Old Dec 15, 2022 | 11:05 PM
  #33
c4004matic's Avatar
17 E43; 21 GLS580
Should work too!
Old Dec 17, 2022 | 08:45 AM
  #34
taybae's Avatar
2015 GLK350 RWD daily driver
Originally Posted by nctalkinghead
I went with this one to use with the 14-50 plug at my house (only used a half dozen times since there is an EA 150kw a mile away) and at a parking lot 40 amp charger near my second home.
https://www.amazon.com/MUSTART-Porta...63b24bcb5&th=1
I have the Mustart too, and use an adaptor to connect to an older 3-prong dryer outlet. It works really well. Initially purchases thr J Booster 2 at twice the price but it wouldn't work with the 3prong adapter.
Old Dec 17, 2022 | 03:09 PM
  #35
c4004matic's Avatar
17 E43; 21 GLS580
6/50 vs 14/50..... the 14/50 is heavier duty and thus safer. I have 14/50 in both of my homes. I use carry a Ford mobile 7.5 EVSE which has 2 plug "dongles" a 110 and a 14/50 I also carry a 6/50 adapter. I also carry a Tesla tap mini 80amp. At home I use a Chargepoint home flex which is excellent in all respects. I also bought a 14/50 extension cord that I can put in the car in case I decide to take a trip to the real boonies where there is no other infrastructure. Its huge and heavy so its a SHTF option that I just keep at home. After 10k miles I do my charging exclusively at home ( no DC charging in my area) DC fast charge on road trip ( succesfully every time) and have used the Tesla tap only once at a hotel just to see how it worked (perfectly).
Old Dec 21, 2022 | 10:24 AM
  #36
rbourge's Avatar
2022 EQS 580 4matic, 2022 GLS 450
14-50 is actually NOT more heavy duty than 6-50 ! NEMA 14-50 has a neutral for those 240v devices that also need 120v (such as light in a dryer or oven). Most level 2 home chargers do not need 120v and a NEMA 6-50 is sufficient and uses less copper wiring since you don't need the neutral wire in the cable, thus easier to snake a new line. Both are equally safe with equivalent ground leads. 14-50 pretty standard in homes due to the type of appliances in the home. Often shops will just get by with 6-50 for their 240 single phase needs so if you anticipate charging at some backyard workshop it might pay to carry a 6-50 adapter. Hooking up to a dryer or electric grill outlet on a patio or home somewhere will probably need the 14-50. Life would be simpler if we just had a better charging infrastructure. I have almost no commercial DC fast chargers within my EQS driving range.
Old Dec 21, 2022 | 12:11 PM
  #37
c4004matic's Avatar
17 E43; 21 GLS580
Yes its more expensive and more difficult to install, it is also considered industrial grade and found in more public iinstallations. Most public plug use it pecisely because you can plug either 110 or 220 appliances, the 6 50 can only plug 220v. 6 50 is a minimum standard.​​​​​​​ Essentially all EVSE's use a 14 50 plug as standard.
Old Dec 21, 2022 | 02:46 PM
  #38
rbourge's Avatar
The fact remains the neither is safer than the other and both are equally robust if from the same manufacturer. You can't claim 14-50 is better just because that's what you have and use. The two standards exist to address different needs and 6-50 is fully adequate for a home wall mounted EV charger especially if the outlet has no other intended use.. Many offer either option plug and adaptors for that reason!
Old Dec 21, 2022 | 03:19 PM
  #39
c4004matic's Avatar
17 E43; 21 GLS580
Sure......
Old Dec 21, 2022 | 03:29 PM
  #40
pmichaelmd's Avatar
2022 EQS 450+ Pinnacle
I have a BougeRV Level 2 portable NEMA 14-50 charger (32A) which works well in the 50A outlet at my hospital and installed a Wallbox Pulsar Plus level 2 (40A) at home which gives me the max 9.6kWh charging speed. Wish the on-board charger yielded a higher level 2 charge rate, but it gets the job done overnight and I don't plan to charge more than once a week unless I plan longer drives.
Old Dec 21, 2022 | 03:55 PM
  #41
c4004matic's Avatar
17 E43; 21 GLS580
I agree a 11kw charger would have been great. In europe some areas can opt for a 22kw one. In the anything over 50 amp charger would be a major expense to instal. Ford offers a 22kW wall unit for their F150 Lightning. It makes sense since the batteries in pickups are enormous, without those you couldnt fill the battery overnight. 9.6 is ok . When on the road I us a Ford mobile charger wich is only 7.5 and it does fine too. Most public level 2 chargers are only 6.6 and if they are double you get only 3.3 when some uses the othe tap. Which is, quite frankly, very bad. The best lelel 2 public chargers to find are Teslas. They vary in speed but most will be 9.5 kw or better so you can get your fastest level 2 speed with your Tesla tap mini 80.
Old Dec 21, 2022 | 04:06 PM
  #42
pmichaelmd's Avatar
When I had my Revero GT I was only able to get about 7 at max, but that only had a 28.5 kW battery so it was quick. I used the Electrify America superchargers when driving up and down 85 on the loaner EQS 450 and was able to get a rate between 92-150. I didn't realize how quickly 30 min passes by when wandering Sam's Club or Wally World with kids!
