EQS EQS (V297) sedan
Significant Change in Range Estimates
Old Dec 16, 2023 | 03:30 PM
Radman991's Avatar
2005 SL 500. 2015 S550. 2016 GLE400 2018 S560
I realize there has been several discussions about range estimates on the car but I wanted to share my recent experience.
I have typically been driving in local traffic, occasionally on the highway for a short period of time in southern Florida. Temps have been in mid 70’s to low 80’s. I recently charged up to 95% and made a round trip to Orlando and back traveling on I 95 and the Florida turnpike averaging 75 mph. I did about 300 miles round trip. Before I started the trip the range estimate the car was reporting was 403 miles at 100% SOC. Now I know that is very generous, but now after the trip my range estimate at 100% is 327 miles, the lowest I’ve seen since I’ve had the car in Florida. I’m confused, because the recent consumer report article stated the EQS 580 sedan range was significantly better than 327 miles on the highway at 70 mph. I wouldn’t have though range dropped that much. Any thoughts?
Old Dec 16, 2023 | 03:55 PM
AppleFan1's Avatar
2025 EQS580
I’m pretty sure the drop in range is due to the fact that your average speed was 75 mph. I don’t think the Consumer Reports is accurate even at 70 mph. Your range will be considerably higher at 65 mph. The best range by a lot is in city driving.
Old Dec 17, 2023 | 06:17 AM
pmichaelmd's Avatar
2022 EQS 450+ Pinnacle
Agree with the other post, likely the difference between 70MPH and 75MPH plus any other factors that remove ideal conditions (elevation changes, wind, temps outside of the box, use of A/C, tire pressures less than 41/48 or whatever is recommended for your tires).
Although irritating, try the trip at 65-70MPH next time and see what you get
Old Dec 17, 2023 | 06:22 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
In ICE cars, mpg crashes going fast. I saw an article years ago that a Camry was getting like 22 mpg going 80mph. Our cars might be even more sensitive to driving at higher speeds/eating more kwh.
Old Dec 17, 2023 | 10:52 AM
Radman991's Avatar
I should also add that it was near gale force winds as I drove up and back as well. Figured it was the combo of wind and high speed that knocked range down, but the car drives so smoothly it’s tough not to drive 75-80 on Florida’s turnpike, especially late at night.
Old Dec 17, 2023 | 10:54 AM
perlfather's Avatar
911
Assuming other variables (outside and inside temperature, tires, inside electrical load, passenger weight etc.) are fixed, the milage/range should be inversely proportional to velocity. Air resistance (=coefficient of drag*frontal area) is proportional to the square of velocity. However, time to cover the distance is inversely proportional to velocity (takes less time at a higher speed), so consumption is proportional to velocity. (In an ICE car, only ~30% of the energy produced by gasoline/diesel is used to move the vehicle; the rest is heat. Not so in an EV!
Thus, assuming no change in elevation, if you travel at 75 mph you would use about 15% more electrical power than when you travel at 65 mph.
Furthermore, it is easy, for example, to calculate the additional power required for an EV to climb a hill/mountain. (=total weight *9.8*elevation gain/time, not counting rolling resistance). There is not a lot of wasted energy.
Old Dec 18, 2023 | 08:30 PM
MBNUT1's Avatar
2010 E350 4Matic
The aero drag impact on range is inversely proportional to the velocity squared.
Energy is equal to the amount of work done. E=W
The work done is equal to force F times the distance D that the force is applied. W=K1*F*D
The aero drag force Fad is proportional to the velocity V squared. Fad=K2*V^2
Therefore:
1. E=K1*K2*V^2*D
Let:
a) K=K1*K2
b) B (the battery capacity) = E
c) R = the range
Substituting a, b, c above into 1.
2. B=K*V^2*R
Or
3. R= 1/K*B/(V^2)
Having said the above, the range is more complicated in that I think that the mechanical losses tend to be proportional to speed and the HVAC losses are related to the time traveled. So in the case of HVAC the consumption of range actually decreases with speed (well sort of because heat transfer does increase with speed)
Old Dec 19, 2023 | 09:57 AM
perlfather's Avatar
911
Originally Posted by MBNUT1
3. R= 1/K*B/(V^2)
I do not think that is right. Suppose the range is 360 miles at 40mph (v^2 = 1600). Then, when you double the speed to 80mph (v^2=6400), the range would drop to 90 miles (6400/1600). Does not seem real - double the speed and reduce the range by 1/4. What am I missing?
Old Dec 19, 2023 | 10:49 AM
MBNUT1's Avatar
2010 E350 4Matic
What you are missing is that the aerodynamic piece is fraction of the total consumption. In addition to the mechanical and HVAC losses, there are other factors such as motor efficiency which varies with load and speed.
Old Dec 19, 2023 | 04:38 PM
perlfather's Avatar
911
I am not knowledgeable about this, however, from what I have read, the rolling resistance of the tires is very small, and total power consumption by heating, A/C can be precisely calculated and relatively low. (assume very small at ~70F) With electric motors, where does the loss of efficiency go? Heat? (Tesla claims that their Model 3, and the Tesla Model Y drive system has an efficiency of around 97%!
Have a look at these calculations: https://physics.stackexchange.com/qu...air-resistance
It concludes that almost all of the opposing force on the vehicle is air drag.
Old Dec 19, 2023 | 07:20 PM
MBNUT1's Avatar
2010 E350 4Matic
The EQS has a drag coefficient of 0.2 and a frontal area of 2.51 square meters.
Applying the drag force equation 1/2*rho*Cd*A*V^2 at 70 MPH results in 0.135 kWh of consumption per mile. Consumer Reports test at 70 MPH resulted in a range of ~380 miles. Given the 108 kWh battery this is a total consumption rate of 0.284 kWh/mile so the aero drag was about half of that.
Old Dec 19, 2023 | 07:30 PM
perlfather's Avatar
911
Thank you. That makes sense.I would have thought it would be higher, however, this is strong evidence. So is the rest rolling resistance, motor efficiency, driver comfort and friction in the drive mechanism?
Old Dec 19, 2023 | 07:53 PM
MBNUT1's Avatar
2010 E350 4Matic
Yes I would think so.
Old Dec 20, 2023 | 07:22 AM
nath_h's Avatar
I'm just super impressed with the knowledge on this forum...wow. I remember hearing years ago that a Tesla would be out of power in ten minutes running wide open.
