Mercedes Wallbox
https://link.bdainc.com/mbwallbox/
I just got my wallbox confirmed from 1 credit I had. thank you thank you LOL
Hopefully, you will qualify for the free wall box.
Nick
Amazon link to the 14-50 Cord 10 ft.
I bought all my charging gear from https://splitvolt.com/collections/extension-cables
1. Did you install GFCI for the outlet? Sounds like something I missed doing earlier and should look at doing now? Could you share product link, if possible.
2. If I were to hardwire, can I just extend the prewire by hooking up 6/3 wire? The current location is not ideal and unfortunately I can’t just install the charger at that location. Not sure what splicing two 6/3 wires entail. Just like you, I am tech savvy, have done plenty of electrical work but not an electrician!
Thanks!
This is what I ordered:
50 feet round trip, you would lose about 20 volts, so a 6Awg could go 100Feet for a 50Amp.
Per Mercedes Wall Box Manual: Solid Wire: 16mm (6AWG Copper field wiring rated at 90 degrees C (194 degrees F)) Stranded wire with Ferrule (Without plastic Sleeve (Maximum 16mm Terminal Block) (6 AWG)
Maximum Charge Rate: Up to 11.5 KW (240V Split-phase, 60 Hz, 48 Amp)
Conduit Diameter: 3/4 Inch
I am not an electrician, please consult with a licensed electrician.
