New G55 owner and thoughts on brake upgrades in dubai :)
Old May 23, 2012 | 03:42 PM
Chirenj's Avatar
Mercedes G55 AMG
Hey,
Just got the G55 a little over a month back wanted to introduce myself on the forums been following this forum for quite a while. Wanted to know if anyone here has any experience with looking at Brembo brakes or any other options i could consider.
Attached Thumbnails New G55 owner and thoughts on brake upgrades in dubai :)-301823_10151504663730357_877890356_23957206_539824040_n.jpg   New G55 owner and thoughts on brake upgrades in dubai :)-533176_10151504661850357_877890356_23957201_922852111_n.jpg   New G55 owner and thoughts on brake upgrades in dubai :)-546124_10151504660130357_877890356_23957194_1780277888_n.jpg   New G55 owner and thoughts on brake upgrades in dubai :)-56184610151504657970357.jpg
Old May 23, 2012 | 06:44 PM
jimmyg's Avatar
2013 G 63 AMG
Congrats! The G55 already has AMG 4-piston high performance front brakes. What is your goal with upgrading them?
Old May 23, 2012 | 10:03 PM
Chirenj's Avatar
Mercedes G55 AMG
Well i use the g as a daily driver until a week ago had to leave the country for uni and i noticed the brakes started to wear out really fast, i almost din't stop in time on emirates road (Could have been a nasty incident), so i was thinking if i switch to high performance brakes rear and front, or maybe its just my existing pads are faulty. What do you think?
Old May 23, 2012 | 11:56 PM
3WD's Avatar
3WD
SPONSOR
Car
Hello,
The Standard OEM brakes for the G55 should work effectively on your vehicle. Only reason we would suggest you doing a BREMBO 8 Piston Front and 4 Piston rear is if you decide on doing some performance and wheel upgrade. Now, having the BREMBO upgrade can't hurt you as well. The BREMBO will definitely help you stop your vehicle a lot faster at a shorter distance. Going from a factory 4 piston to an upgraded 8 piston will change the braking ability on your G55 a dramatic difference.
Thank you
By the way, NICE CAR!!!! =)
Old May 24, 2012 | 12:33 AM
jimmyg's Avatar
2013 G 63 AMG
Most likely it's your brake pads. Gargash will be able to tell you what's the condition of the pads and whether they need replacing. In terms of braking distance, on the G55 the limiting factor are the tires not the brakes. The G63 has larger diameter wheels and higher performance tires, so that's why they are using the 6 piston calipers from the ML63. Best way to improve braking distance would be to get stickier tires...at the expense of tread life, road noise, and off-road durability.
Old May 24, 2012 | 10:25 AM
Chirenj's Avatar
Mercedes G55 AMG
Awesome, will go check it out at gargash as soon as i'm back. Appreciate the replies
Old Jun 29, 2012 | 03:52 PM
Chirenj's Avatar
Mercedes G55 AMG
Since i've never driven a g55 except the one i own, i was just wondering if the suspension is that stiff when bought stock because even i tiny bump on the road feels like I'm on rocks. I s this normal?
Old Jul 1, 2012 | 12:29 AM
jimmyg's Avatar
2013 G 63 AMG
They were very stiff on the 2003 G55, and are only slightly less stiff on current models...but it's a pretty jarring ride...harsher than my Aston. AMG does this to improve high speed stability and to try and compensate for the high center of gravity in corners. You can replace the shock absorbers quite easily with the ones from the G500. Another, more expensive option is the BRABUS Ride Control Suspension upgrade.
Old Jul 9, 2012 | 01:33 PM
mzcloud's Avatar
06 C55, 15 S550, 16 G550
What is the preferred type of tired for G wagons? I don't think the stock Yokos are any good
Old Jul 9, 2012 | 04:39 PM
jimmyg's Avatar
2013 G 63 AMG
The Yokohama AVS/ST on your G55 was superseded by the Yokohama Advan ST which is a much better tire. It's what is used on the G63 and G65.
Old Aug 26, 2012 | 03:06 AM
BonitaBeast's Avatar
2017 G63 Edition 463, 2008 G55k
Originally Posted by 3WD
Hello,
Thank you
Hi,
Does the Brembo Big Brake kit for G55s fit under the stock 18" AMG rims pre-2009?
I take it you sell the kits for front and rear?
Can you please PM me how much for a front Brembo Big Brake set of Silver or Black calipers with Slotted rotors shipped to Redwood City, CA 94065?
Thanks!
Old Aug 27, 2012 | 04:56 PM
3WD's Avatar
3WD
SPONSOR
Car
Originally Posted by BonitaBeast
Hi,
Thanks!
Hello,
We will be PMing you details shortly.
Thank you
Old May 12, 2013 | 03:26 PM
Amnaggar's Avatar
2010 G55, 2010 C250, Volvo S40 T5, Pajero, Passat, 1995 SL500
I have this Brabus system.. Came on the 2010 G55 I bought last week from Reem Auto... Great difference ofcourse, but makes me feel I want to try the original G55 suspension to see if they are as stiff as the Brabus (turned On)... Ofcourse turned Off they're quite nice...
Old May 13, 2013 | 06:58 PM
3WD's Avatar
3WD
SPONSOR
Car
The Brabus Ride control is an amazing unit, trust us when we say this, most of the customers who've had regular suspension and went over to the BRABUS system, LOVES the Brabus system before of the comfort.
Old May 14, 2013 | 03:31 AM
Amnaggar's Avatar
A little wobbly though if on an imperfect highway.. I find myself turning it on on high speed to add stability.
Old May 27, 2013 | 03:43 PM
Amnaggar's Avatar
Just noticed today, that brakes aren't that fast to take effect if you slam it! Felt it even dangerous and won't save a person or a car 2m in front of mine even if at low speeds, like easing out of parking, or just after starting to move at a green light, for instance! Too soft and cushiony, not hard with immediate effect! Does that sound normal to you guys?
Old May 27, 2013 | 09:43 PM
You need to bleed your brakes. That sounds normal after the brake fluid has overheated a few times or you have developed air bubbles in your brake system. You may want to check the condition of your pads and rotors as well.
If anything, definitely bleed the brakes though, before you slam into the car in front of you
Old May 28, 2013 | 02:40 AM
Amnaggar's Avatar
Will do for sure.
Old Jun 3, 2013 | 01:29 PM
Amnaggar's Avatar
Been sensing an issue with the Brabus shocks... turned to soft (light on button OFF) I get a wobbly steering/car at around speeds of 60 and up (km/hr) if road is not absolutely perfect... once I turn to stiff (light ON) things are almost totally normal and under control... Been the Brabus ten days ago, before this really made itself that obvious, to ask the guys there to check whether shocks are in good order (bought car last month with them installed by 1st or 2nd owner). One of their German managers asked (in German, which I don't understand) one of the German mechanics to come look at them.. said they are originals and that I shouldn't worry about them and that they are approved by the German government! Does that mean they are God-like and will never ever go wrong, even if abused?! My answer is NO. I thought to first go down the route of wheel balance, but then again wheel/car would have wobbled and shaken anyway, even if Brabus system on stiff ride setting, if wheels aren't balanced...
Any thoughts?
Old Jun 3, 2013 | 02:08 PM
yetis's Avatar
G550
G wagon brake question. Will AMG calipers fit on a G550? What are ones options here? I see there are big brake kits for the G55, but don't see any options for G550's. I am loving everything about my new truck except for the brakes and I wonder if at 30k miles of NYC driving, if the shocks are a little worn. Any event, what are the options for brakes on the G550? I am sorry I didn't move fast enough on a recent set of Brabus suspension. Was just too early on in the learning curve.
Thank you
Old Jun 3, 2013 | 02:25 PM
Amnaggar's Avatar
Thank you[/QUOTE]
Better save than sorry
Old Jun 3, 2013 | 10:27 PM
yetis's Avatar
G550
Maybe just a technical question. According to Brembo, the front and rear big brake kits from Brembo are the same for the G500 and the G55 MY03-04. Then they say that the fronts changed on G55's for MY2005 onwards, while the rears remained the same for all G wagons. However, there is NO mention of the G550. Does an AMG 2008 caliper fit on a G550? Maybe its just easier to get AMG.
http://www.brembo.com/en/car/Racing/...PPLICATION.pdf
Old Jun 4, 2013 | 11:22 AM
pagepro's Avatar
Any thoughts?
You probably need to get the Brabus Ride Control Upgrade Kit (463-016-81). It was launch in 2012. This upgrade will allow your Ride Control to switch automatically from Soft to Hard Setting if its senses your car is feeling unstable.
There were probably some complaints like yourself, and brabus now offers this feature on all new Ride control from 2012 onwards.
Old Jun 4, 2013 | 12:17 PM
Amnaggar's Avatar
Thx! I told the Engineer that it was installed a few years ago post-2010 and he still said that it actually reverts to stiff setting if it senses turbulence above 120km/hr. I don't know if the kit u refer to is different than this. But since the shocks themselves do allow for turbulence to happen, that's a) bad and b) means mine are ok, but even the slight shaking I get (more if road isn't perfect and at mere speeds of around 60-80km/hr!) is strange, physically and safety-wise uncomfortable, coming from a product that is "approved by the German government"
Anyway, I'll drop by Brabus tomorrow and annoy them a bit about this and see what they'll come up with this time!
